Hello agen, this time im after setup info fore gerber grylls paracord fixed blade like Angle and what Depth key i shuld us?, i cant fine eney info about this knif in the database, and do eneybody haw a othe database hompage whit angle info to WE to recomend?
In a quick Google search I found this info:
Gerber Grylls Paracord
• Overall Length: 7.75â€, 19.7cm
• Blade Length: 3.25â€, 8.3cm
• Weight: 5.75 oz, 163g
• Steel Type: 5Cr15MoV
• Handle Material: Paracord
Does that sound like the same knife?
On the blade angle Gerber makes a general statement. http://www.gerber-tools.com/Maintenance-tips.htm says : “Gerber knives are sharpened with a uniform 15° angle on each side for a total of 30°.â€
I’m not the one to advise you on the settings for depth and other clamping settings.
Hope this helps.
