Thought I’d share a couple of photos… I picked up one of the Vacuum Base vises at Lowe’s (mentioned elsewhere) and decided to use for mounting the Field and Sport unit. Turns out very simple… just unscrew the baseplate that holds the vise, take out the center bolt, add a washer (so the bolt won’t go thru the hole on the bottom of the F and S unit), and bolt it down!
(Knife is a Kershaw Echelon 1880).
When done, it comes apart and fits nicely in the toolbox I had, along with other stones, etc.
You’re welcome. Yea, that’s where I got the idea from. Nice thing about this… no extra parts are even required. (Took me longer to figure that out, then to actually do it.). :blink:
Well at least it wasn’t a back and forth from home to the hardware store. Seems like I spend a lot time doing that some days or buying way too much to make sure I don’t have to go back and forth :lol:
[quote quote=“cbwx34” post=6602]You’re welcome. Yea, that’s where I got the idea from. Nice thing about this… no extra parts are even required. (Took me longer to figure that out, then to actually do it.). :blink:
(The vise/base…)
[/quote]
no joke! i mounted my full WEPS to the same vacuum base, but it looks like the F&S works out even better! Mine’s kind of a pain to store… not as “flat”
[quote quote=“cbwx34” post=6600]Thought I’d share a couple of photos… I picked up one of the Vacuum Base vises at Lowe’s (mentioned elsewhere) and decided to use for mounting the Field and Sport unit. Turns out very simple… just unscrew the baseplate that holds the vise, take out the center bolt, add a washer (so the bolt won’t go thru the hole on the bottom of the F and S unit), and bolt it down!
Holds well and works well! Piece of cake! :side: :)[/quote]
I think and am pretty sure that credit for the original idea was presented by The poster “Changeofseasons”.
I contacted him and he is sending one my way.
