Double Bevel
Yoda’s
Pertaining to double bevels
Step 1 Pick your primary bevel (say 20 dpi)
Step 2 create your burr
Step 3 work through your stones and ceramics for your polish
Step 4 create your secondary bevel ( say 22dpi) with 600 diamond stones, now the question do yo create another burr?
Step 5 ? Follow with higher grit stones
Step 6 ? Strop
It should create a burr almost immediately since you have already apexed the edge previously. Just use the last stone you plan on using for your micro bevel. (600-1000 grit is usually the sweet spot) depends on where you finished your other bevel at. :wink:
