[quote quote=“JeffSimmons” post=3101]I did some browsing but may have missed if this topic has already been posted. If so, I apologize and point me to the post…!
I was wondering what type of care should be given to the stones and the leather stops both to reduce contamination and wear. Obviously I want to extend the life of these as much as possible as well as have them able to continually give me the edges I’ve been getting.
Is there a cleaning proceedure (particularly for the leather strops)?
How often do you guys clean your stones/strops?
How long should I expect the diamond stones to last? I am doing some re-profiling with my 100/200 stones but not too much and I can already feel the stone smoothing out after 8 sharpenings. Is this normal.
Thanks in advance![/quote]
Hi Jeff,
The smoothing out of your plates is normal and desirable
I can not speak to leather stops but as far as Diamond plates you might just want to use an old tooth brush and mild soap and warm water. I have seen posts from time to time about using ultra sonic cleaners. That is the worst advice, as ultrasonic cleaners will quickly dislodge the diamonds from the bond and release them from the substrate.
Here is some poop from the DMT web site:
Clean your DMT® sharpener after each use with water and wipe dry. After several sharpenings, use a mild kitchen abrasive cleanser and a nylon scrub brush (an old toothbrush works well too). Comet, Ajax, and Zud work well. Make sure the sharpener is dry before putting it away. If you are concerned that the diamond may have worn off the stone, rub the sharpener against an old glass jar. If the sharpener scratches or frosts the glass, then there is diamond on the sharpener ready for your sharpening needs.
Although you should NEVER put your diamond plates in an ultrasonic cleaner, you can certainly try it with a ceramic stone as there is no danger of disassociating the abrasives from the bonding matrix. There is also another trick that us jewelry makers use to remove unwanted oxides and metals from gold. A quick soak in mild sulfuric acid. (Diluted pool acid from you local Home Depot works well..) This will work on your ceramic sharpening stones. But do not try it on diamond plates, although the diamonds are non reactive, the aluminium and steel plate they are mounted on are highly reactive.
The following micrograph of one of my dirty ceramic plates shows an accumulation of metal. An acid bath would make quick work of cleaning this up. If you try it, remember that the fumes generated are toxic, and you should work outdoors with a breeze at your back. An organic vapor respirator would be a good idea as well.
