Convex bevel width; primary bevel scratching
Hey, y’all.
Made it to Hawaii. Helping folks teraform the lava. One more month, and I’ll be back in the forum more.
I’m practicing convexing. Love it deep, and smaller bevel sizes are easier to blend. Ground a drawknife into my machete, 1/2 inch convex bevel. Ended up doing 5 bevels: 18/14/12 as large bevels, 16/13 small to knock down the larger bevel edges. It’s beautiful, but I wasn’t able to blend them to a perfect curve… Still facetted.
Anyone experimented with blending bevels over a larger area? I’ll probably just need to do bevels each °. I’ll test it, but it may be a mm, or 1.5 mm bevel width max for seamless blending.
Another thing: I’m leaning more towards the method of doing the lowest angle bevel first, then the highest for apex, then bevels between. Problem is, on doing even 2° higher than apex bevel, the apex bevel gets scratched… Happened twice, and chapped my hide. Any idea what could be going on, or how to avoid it? I’m wondering if the swarf/grinding powder isn’t getting built up and getting dragged over the polished edge…
Sorry about not replying to all y’alls previous replies. I will, once I get back on the road for sweet, sweet R&R. Chomping at the bit to listen to everybody’s suggested playlists.
<p style="text-align: left;"><!--more--></p>
  • I ment 2° lower than apex bevel still scratches it.
I’ve only done convex on very thin knives, so my experience might be a bit off on this one. I think the facets you are getting are because of the large angle change between steps. I’ve been stepping 1/2 degree at a time, with a total of 4 degrees. Works great for thin knives. I also keep the number of strokes with each step to a minimum, After reaching an apex polished to 800 grit, I then step down 4 degrees in 1/2 degree steps and take maybe 3 or 4 strokes with the 800 at each step. After finishing the 4 degree facets with the 800, I start all over with the 1000 stones, first polishing the apex, then stepping down to the 4 degrees with 3 or 4 strokes at each step. I continue this with each of the following grits: 1500, 6 micron and 3 micron. You can see the facets by the scratch patterns (I alternate directions with each grit change), but the diamond film has just enough compliance to round the edges of the facets.
With a machete, I would still go with the 1/2 degree steps, but you’d probably start the convex protocol with a lower grit - maybe as low as 400-grit.
With the smaller steps, I think you can take fewer strokes at each step and this should make the facets less obvious.
Good luck Drew.
Maybe using the strops with emulsion (which burnishes instead of abraids) would smooth over the facets. It would take some experiments to determine the effectiveness against 2, 1, or 0.5 deg facet changes but with a USB scope you should be able to tell pretty fast. I love what the burnishing does to my bevel. I follow the “back off 2 deg from the apex” rule of thumb to avoid rolling the edge and it works great.
Tc: that’s an interesting progression. Very possibly a high-contol method. Good God, 8 bevels… Though, I’m intrigued by the possibility of only 4 strokes per grit per bevel. I had been finishing each bevel up to 6um platens, thus the scratching on the apex bevel by the 600 grit used just below it… If one were to finish off polishing grit for grit, lowest angle to highest, it would negate the risk of scratchings. (I’m hoping.) I may have to mix Method 3, as spoken of on Molecule Polishing, with your 1/2° version of Method 2 to get a really shallow, 1/2 inch, perfectly blended drawknife convex. Thank you so much for that. (Organic mentioned that M2 would leave more metal behind the apex than M1 or 3. Have you found edge strength to be good on your 1/2° version compared to a sturdy V?)
Readheads: Indeed, I’m loving strops on smaller bevels! A three-tier series, 2° apart, finished center bevel with hard pressure. Potato cleaving sweetness, right there. Just ordered the 14/10um and 1/.5um strops… Some little birds told me 14/10 might fit in nicely after the 1k. Cannot wait to experiment with them.
Sigh. I missed you all.
I should point out that I do the 1/2 degrees steps on my Gen 3 Pro, where that’s really easy. If I were trying to decide how to manage it with a thicker blade, I’d finish the apex with the 800 grit and then I’d make the first 1/2-degree step down and then watch to see how many strokes it takes to get the new scratch pattern close to but not touching the apex. This would give you and idea of how much steel you’re removing and how many strokes it’ll take at each step. After 800-grit, not much additional steel is removed. I’ve developed a habit where every grit has a stroke direction change from the one before it. Also needs to be said that I don’t try to achieve mirror finishes and that you may require additional strokes if you’re OCD.
tc: I’ll definitely try that. I have to experiment with alternating scratch patterns. I’ve been focusing solely on scrubbing and up-forward strokes, but it sounds like too good of a skill to pass up.
How do you determine the lowest grit to start each bevel below the primary? I want to avoid scratching the main bevel each time I drop down in degrees, like the first few times. You ever apex to 800, drop down 1/2°, use a 200, and find a few deep, weird scratches into the 800 grit pattern? If these stones are flat, and the cube is spot on, I don’t know how to explain that.
Tomorrow we’re cleaning up from a project, then I get to experiment on 6 convex kitchen knives. We’ll see how this tactic fares on tiny bevels.
Thank you, again.
Actually, on rereading your first post, it sounds like you do all the bevels below at 800, with 400 suggested on machete. I’ll bet I was using to aggressive a grit and scratching the bevels above.
Which grit to start the convex facets on depends on how much steel is to be removed. I’ve never gone backwards in grit progression, so producing scratches on previously polished bevels isn’t a problem. As I’ve said, I haven’t tried putting a convex edge on a thick blade, but each step removes very little steel, especially when taking 1/2-degree steps. When I start the secondary bevels, I watch to make sure I’m not erasing the primary bevel all the way to the apex. For thin knives, it’s been a few as three strokes.
If I haven’t been clear on it, let me explain further, with a typical, thin blade…
Regardless of which grit I’ve started the sharpening process with, I take each grit to the apex, erasing most, if not all the scratches from the previous grit. If I’ve decided to start the convex facets with my 800 grit stones, when I’ve finished the main bevel at the apex, I’ll then step down thru the convex facets with that 800-grit stone: -0.5 degrees, -1.0 degrees, -1.5 degrees, etc. Having created the series of convex facets with the 800-grit, I then go to the 1000-grit and follow the same sequence: apex, then -0.5 degrees, -1.0 degrees, -1.5 degrees, etc. Having finished with the 1000-grit, I then switch to the 1500-grit and so on and so on, all the way to my ultimate polish. When I’m done, the convex profile should be very nearly the same degree of polish as at the apex.
You should not require as many strokes for each convex facet as you would at the apex. This is because you are removing a relatively small amount of steel. Theoretically, you shouldn’t need as many strokes at the apex with grits following the initial creation of the convex facets. This is because the width of the apex bevel has been reduced.
tc: got it. And the 1k on up doesn’t remove much steel, like you said, so you don’t have to worry about erasing each bevel when you go through polishing. It sounds like a smart plan.
I’ll apply it this afternoon instead of the 14° apex, 20° apex, + 2 intermediate bevels method.
Drew, just to add this, even though the tolerance of the stone paddle handles on the guide rods are pretty tight, by changing your finger placement and applied hand pressure along the paddle handle length, from holding it by the lower end to holding it by the upper end, while sharpening in each 1/2 º angle setting, this too will help blend your facets.
MarcH: Seriously? That’s a juicy tidbit. Main pressure on the top three finger indents, or fingers placed from top, then palm lower?
I wonder if this has been throwing off the cube, too. I measure each time from top level with stone. Do you place cube top to measure, or mid stone?
I know I’ll be changing a bunch of variables at once, but I’ll try the finger pressure along with the 1/2° method at 800 grit.
Thank you.
I place the cube in the same position relative to the stones, and hold the stones in the same position relative to the knife edge, on both knife sides, each time I measure and set any guide rod angles, for consistency. For me the cube is usually even to the top of the stone. Remember our angles we measure are relative angles of the knife’s bevel relative to the imagined vertical knife center line. These are based on the digital angle cube zeroed to a flat horizontal position on the base. (I use this same position each time I check the cube for zero, again, for consistency). So each time, if you use a consistent method and technique to make your measurements and adjustments you should get consistent results.
The same thing goes for my sharpening strokes. I use consistent finger placement on the stones. Find what is comfortable for you and use this grip consistently. If your technique is repeatably consistent you’ll see predictably consistent results every time you re-sharpen the same knives. If it’s clamped the same each time.
Only when I choose to steer the stones action on the bevel do I move my finger placement to direct the stones point of contact more precisely.
All of these results are observable using a lighted magnified visual aide to see the scratch pattern your creating with your stone work. I use a USB microscope used with a laptop computer.
MarcH: Gotcha. That’s a really good suggestion. I’ll pay attention to the finger placement on the stones, and find a position that’s comfortable and repeatable.
The neighbors must think I’m either a tweaker or on the spectrum. In my hut on the pitch black lava, headlamp on, scratching arcs over and over for hours at night… Maybe I do have a good touch of autism. Your talk of consistency and repeatable patterns give me a soothing reaction.
All these suggestions are pure gold. I consciously appreciate them.
I also try to do things as consistently as possible. Holding the stones at the base of each paddle is my preference because it is consistent and it helps keep my hands below the edge of my knife for an added layer of safety. My fingers can’t get cut if they never go above the blade.
Just to re-affirm what Marc points out… even with the improved fit between handles and guide rods, there is still a significant change in angle between pressure applied below the edge and pressure applied above it. The stone will “rock” about the edge as a lever on its fulcrum. It can be close to one full degree on my rigs. If I see that I’m not erasing the scratches from the previous grit near the apex, I usually can simply move my hand up on the handle to correct the error. Even my bushing-equipped handles, which have nearly zero slop will show an angle change of several tenths.
Angle change and Organic’s comment about preserving your fingertips has been part of my sermon for a number of years now. Fingers below the edge - good. Fingers above the edge - bad. Try placing your thumb in the second groove from the bottom. That should place you index and middle fingers in the second and bottom grooves. Then stick with it, for consistency. And when setting your angle with an AngleCube, try to apply the same amount of pressure at the same point on the handles
I just checked, and with knife contacting center of stone, there’s .3° change between top and bottom pressure… Just spent 10 minutes staring at the WE, going “…huh.”
I sure as sin’ll be holding from the bottom now, but it complicates using the cube on the 1.5k stone. I’ve always taken readings from top closest corner. I didn’t find any difference between cube reading top or bottom of stone, but is there some hidden danger at reading angles at the bottom?
Tips are going to be more challenging. I see the safety benefits of grip bottom. The only real bad cut I’ve gotten is scrubbing the tip, sliding off, then pulling back. Tip carved a good miniature version of a fillet mignon steak out. But, gripping bottom feels a lot less stable. Stone wants to roll on the blade off parallel. Just slow it down for tips?
Feels like I just leveled up in a video game, and all the same monsters just got harder. Good trade for consistency, though.
That’s a good idea, using the “slop” as extra reach when needed.
Off to go redo all the knives in the house. No wonder my convexing was getting scratched. You all are career-savers.
Drew, remember the angle setting of your bevel is “relative” to that knife individual knife clamped in that orientation and that specific position in the vice jaws. It is a relative angle not a true or real angle. All that matters to match that angle again is consistency. It truly doesn’t matter where or how you place the magnetic digital cube on the stone as long as you do it the same way consistently, each and every time you set the angle on that same knife. You may find that on some knives it’s easier to place the digital cube at the bottom of the stone. As long as you do it for each knife, again, the same way consistently, it’ll give you repeatable relative angle settings. I try to do everything the same way all the time for simplicity of the consistency. If I have to change up my technique or method, I note this in my sharpening log, where i can record specific comments on sharpening each particular knife.
In reality a bevel you sharpened to 15º per side with your Wicked Edge may be different from my 15º bevel on my Wicked Edge. It may measure with a Catra device at a true 14º or a true 15.5º. It really doesn’t matter. If the bevel angle we applied using our individual Wicked Edge Systems, that we measured to be 15º is sharp and it cuts and works well for us, this is all that matters. If it measures at something other than 15º with a true measuring device it doesn’t make the edge any less sharp or a bad angle. Too much emphasis is placed in the angle number when we knife sharpen. Like it gives bragging rights or make the knife better. All that matters is the knife’s performance. And that is very personally subjective also!
You may want to look into these safety tools.
Ok, I did a few days of convexing, holding the stones at the bottom, and taking readings from the bottom of the stones. I’ve got to tell you, I will never hold the stones up high again as a default technique again. I can feel the shape of the edge so much more finely, and my bevels have never been so crisp.
I highly suggest telling newbies about the angle changes with top and bottom grips. I only remember reading about the safety aspect. This is like discovering second gear after driving for months in first.
Thank you all. I’m seeing the results that I can finally be happy with.
PS, Marc: I bought a pair of cut proof gloves on Amazon. Good suggestion. Also, I could get addicted to precision measuring equipment. I’m going to hold off looking into things like the Catra until I get established. But since we’re on the topic, what dual axis protractor would you suggest? Something that registers adjustments quicker than the angle cube.
Pps, tc: I tried the .5° stepdown. The knives I had to work with were freakishly soft steeled CuisineArts. Even the 1.5k stones were too aggressive, and I kept wiping my bevels out… You, my friend, have got to have a surgical hand. I’ll try it again when I refresh these edges in a few weeks, but you may simply be a specialist at a difficult technique. Hat tip.
Ppps, Organic: I’ve been meaning to tell you, your blog guided me to my first successful convex. Screwed the first two attempts up, then just power read your articles for a couple hours. Hella thorough work, man.
Drew I use the Floureon Digital Protractor DXL360S, as does tcmeyer, I believe. It has the specs claiming it is the most precise gauge, with the lowest resolution. I cannot say or claim it is as fast or as easy to use as other devices I have used also, those with very good results, too. I used the Wixey WR300 Type 2 for a long time with good consistent results. I found the Wixey to be the fastest locking and easiest to use gauge of all of them, I’ve tried. On paper it does not have the precision or resolution of the DXL360S, while it never inhibited good, consistent results.
I think that “consistent technique” and “attention to detail” are the largest contributors to your results, more so then using the precision measuring equipment. I’ll submit to you that your improved results with the new hand hold positions is more a result of you gaining a little more experience each time you sharpen and slowing down and paying closer attention to the details then simply the new finger and gauge placement, you employed. I generally place my gauge at the top of the stone and my fingers centered on the stone and I can match a bevel “dead on” with the first stroke that I applied a year ago when I do a edge refreshing touch-up. Each time you sharpen you’ll continue to get more aware and get more in tune with every aspect of what your doing as your stones continue to break in and allow for better improved results. You’ll find you’ll use more of your senses and the sound of the stones becomes a good tell of how well you’re bevels are getting.
