Something I meant to mention in the video has to do with the 45 micron DLF. On inspection with my 'scope set at 157X, I was surprised to see that the film is quite different from other films I’ve used. Instead of being a densely packed matrix of diamond particles, they were widely scattered, and I could readily see indentations or pockets where diamond particles were knocked loose in the first few sessions. It didn’t seem to negatively affect its performance and an inspection today showed the same general appearance, even after six or seven additional sessions. Maybe the missing particles were simply not secure enough to prevent such loss? Could it be that the more widely scattered diamonds actually cut better than a more densely packed film?
So here’s a couple of photos of the 45 micron film… The scale is such that the image is almost exactly 2.5 mm wide. On using the Celestron measuring software that comes wit their camera, the dark particles measure very close to the 45 microns. I measured three of the dark blobs and they all fell between 42 and 43 microns.
I caught the light just right so you could see the 3 dimensional effect on dimples where diamond particles used to be. Aside from the widely scattered pattern, here’s the interesting part: This first image was taken after a few vertical strokes - certainly less than twenty.
This second image is of the same film. The only differences are the lighting and the fact that it has seen somewhere between 100 and 200 strokes. It’s been cleaned, but could have somewhat more staining from the dry swarf.
Notice that there doesn’t seem to have been a further loss of particles you would expect after the losses in the first photo. Like the diamonds that were going to come loose have already done so, and the remaining particles are securely attached.
If anything, you’d think that there were fewer diamond particles per square mm in the first image, but I can state firmly that the photos are in the right order. The images were taken in areas rather centrally located, except that they were off center a bit to let light in from the back. They may have been as much as a couple of inches apart.
Are the diamonds scattered because of their cost? There is nothing in the performance that would get you to suspect they were using fewer diamonds. The scratch patterns are beautiful. Bigger diamonds cost a lot more. Ask any guy whose wife had insisted on putting a bigger rock on her wedding ring.
I bought it to be used as intended on flat bench stones, but the coarsest grit I have in those is ~320. Most chisels and plane irons I encounter have been sharpened with files of on bench grinders, and almost universally very poorly–multiple bevels and badly out of square.
I recently purchased the 50/80 grit paddles for my WE, so those seemed to be ideal for hogging off some very hard steel to restore the edge, but I’m too cheap to buy the WE chisel/plane adapter, so… I just flipped the guide upside-down and clamped it into a drill press vise. Now I can sit at my desk, watching YT videos while I sharpen my chisels and irons!
But…
gotta pay attention!
That plane iron was about 1/8" out of square and it took me about fifteen minutes to get it to a gleaming, perfectly flat and straight 20 degree bevel and 30 degree micro-bevel.
