Case for Wicked Edge
Lucky,
Here are the prices of the cases that I had inquired about. Foam, is extra but not alot.
Model Price
186 $ 95.70
188 104.50
216 112.20
219 121.00
246 126.50
249 129.80
276 142.50
279 151.80
Has anyone found a tray of some type to hold and separate the stones that works well?
babo
I am going to try thin plexiglass when i receieve my case. As you can drill and tap with screws, and a little glue and that should hold together pretty well.
I use an art supplies box I found at the Container Store - called the ArbBin IDS 600. It has six compartments that fit the WEPS stones/strops perfectly. And it costs about $10. But a small plastic lure box would probably do well too.
TedP
What are the dimensions of the WEPS paddles?
Sintra is super easy to work with easy to cut and Glues up real fast. its PVC so
its strong and almost an instant glue up. Bends with heat easy as well.
http://www.usplastic.com/catalog/default.aspx?catid=733&gclid=CLzz5_TV_6wCFcOP7Qodsi8tRg
Someone needs to get out their Vacuum Bag system add some Flocking to the trays and there ya go :cheer:
Jdee
Each individual handle with stones is 5 5/8"L x 1 3/8"H x 1"W. Of course everything comes in sets of two, so you’d need double the width or height for each set.
I haven’t found one but I did design one that I’m planning to ask my father to make. I’m not much of a wood worker but he is so I’m hoping he’ll make it for me.
Had a friend make it for me and got it this morning. Can’t wait for the rest of the stones I ordered to show up.
[quote quote=“CoryNash” post=2208]Had a friend make it for me and got it this morning. Can’t wait for the rest of the stones I ordered to show up.
[/quote]
Beautiful! That is really well thought out and very nicely executed.
A plastic box from a local fisherman’s shop that happens to fit the WE paddles perfectly… And made by a US company. :smiley:
Very nice!
Yes it is nice!!
Can you tell us if it has some kind of model number, who the manufacturer is, and where you got it?
Thanks,
I bought it at a local Fisherman’s shop, not a chain, in the Netherlands. It is really a cheap plastic box (but very functional :wink: ) without any manufacturer details on it. And of course I threw away the paper wrap it came in that did give more details…
I’ll pay this shop a visit next weekend and see if they have more of these boxes in stock, so that I can find out who the manufacturer is.
Cheers,
Mark
Looks like it could be a Plano Flipsider spinnerbait box. Model number 3744-00.
LINK
[quote quote=“CoryNash” post=2333]Looks like it could be a Plano Flipsider spinnerbait box. Model number 3744-00.
LINK[/quote]
Yup, that’s the one! I immediately recognize the brand name, Plano. The picture on the site of which you provided the link even shows the hanger I cut off, since it has little use. Thanks, you just saved me a trip to the shop :D.
What the photographs don’t show is that there is still quite a bit of room behind the angled stone holders. I use it to store stropping compounds. Plano also have a model that is one size bigger. Might be useful if you have a lot of stones/strops.
Thanks guys…
I just may pick one up … If the shipping is not more than the box.
I live n Denver, Co. Maybe I will check around locally too.
Thanks again !
Mark,
I purchased this case on Amazon (Plano Flip Sider 3744 ), but the lid wont close with the hones in. Did you have to mod, or is this one different?
Dave
Hmm… here it doesn’t close perfectly, but it closes fine. The stones press just a little against the plastic top, but the plastic is flexible enough.
However, the “stone holders” (they were not designed for this purpose) at the left and the right site of the box require you to position the stones properly. If you position them in the wrong place, they will stick out. My Chosera stones (which are slightly thicker than the stock stones) don’t fit in at the left and right stone holders, but they fit perfectly in the middle stone holders.
It is a bit hard to explain, but fiddle a little bit with the stones in the stone holders to get them as low as possible and you’ll recognize what I mean.
I found this case at the container store ( $24.99). The foam insert is precut at 1/4 " intervals so its easy to cut out with a serrated knife. I work farmers markets in the summer and this set up works great for me. I also use a smaller version for my stropping paddles.
