Base tapped
Just ordered my we130 decided to make my own base found the template no problem ...my question is does the blue base have 2 tapped 10-32 holes for mounting?The template shows 13/64 holes which is clearance
Yes, but not sure of the thread pitch.
Great thank you
The 10/32 screws need to be sized to the right length, (not too long). The screws need to get tight in order to hold and mount the WE130 securely, before the screws bottom out in the threaded mounting holes.
