Hello… My first post, so if I sound like a newbie… well… ![]()
Just received my Wicked Edge, and the angle settings do not match each other on both sides. Let’s say I set the rod collars to the 20 degree mark on both sides. I then measure the angles using a digital gauge. On the left, I get 21.1[sup]o[/sup], and on the right I get 21.7[sup]o[/sup]. After a variety of angle changes, I am always off by about 0.6[sup]o[/sup].
I also notice that when I lock the rod collar in to a divot on the base rod, the inside edge of the collar on the left aligns perfectly with the 20 degree marker, but on the right, it covers the 20 degree marker slightly. I suspect this is the cause of the discrepancy I’m seeing from the gauge.
Okay, so here’s the big question: Does it matter? I mean, sure the WE is a lot about precision and I kinda do like the idea of the angles matching on both sides. B) But obviously there is some margin for error. And if you buy a knife from Benchmade, that margin is somewhere in the several degrees range!
The next question is Can I fix it?
Thanks.
-Pie
