What is the advantage
Recent Forums Wicked Edge GO What is the advantage
  • #46355
    sam
    • Topics: 5
    of the riser in the wicked edge 2017 upgrade
    #46357
    Mikedoh
    Am guessing you are referring to the “mounting block” upgrade?
    This description may answer your question.  A greater selection of sharpening angles.
    Precision Sharpener – WE120
    #46360
    sam
    • Topics: 5
    Am guessing you are referring to the “mounting block” upgrade? This description may answer your question. A greater selection of sharpening angles. Precision Sharpener – WE120
    Yes the mounting block how does it help in sharping a knife?
    #46361
    Mikedoh
    If you follow the link, in the description it says “and a Riser Block which extend the angle range to 13-35 degrees per side.”
    The increased height of the vice/knife allows the extended angle range.
    Other than that, I’m at best unsure of what you’re asking.
