Looks great Josh! Can you tell a little more on how you cut the stones? I’ve been thinking about cutting my own stones (Coticules in my case), but have no clue how to do that. Did you use any powered equipment? And did you cut the sharpening area (or the area you taped on the stones) as well? Or was this their original thickness?
I simply marked it out on the stone block into the dimensions I wanted (that would fit inside the Wicked Edge paddles) and then used a tile saw (i.e. saw w/ a diamond blade – all tile saws have diamond blades and are water cooled I was informed) and it cut them like butter, nice clean,straight cuts. If you can get a tile saw everything else will fall into place
