Hi, Just received my upgrade arms for Gen 2. It mentions at the end of the instructions to fix the self adhesive bumpers to each corner of the base plate. I didn’t get any self adhesive bumpers. Are these required? Also in regard to the micro adjust screws, I take it you loosen these and then adjust the allen screw. Is that right?
Not sure about the 1st question… the only ‘bumpers’ I can think of are the ones that can be attached to the bottom of the base that the sharpener is mounted too… I don’t know what that has to do with the arm upgrade though.
You’re right on about your 2nd question.
