Tool stand DIY
Recent Forums Main Forum Knife Photos Tool stand DIY
  • #34802
    Roper
    Not a knife photo but one of a tool stand I made for my diamond stones. Simple walnut  with brass 1/4 inch rods. It keeps the work space neat and orderly.
    8 users thanked author for this post.
    #34804
    That’s awesome, I had another forum member make me one similar to that a few years back and I still use it every day! Mine has several rows though =) It does work super well, the only thing I don’t use it for is strops because I don’t want any cross contamination. Thanks for sharing!
    #34805
    Alan
    • Topics: 16
    Very nice job, Roper.  I like the way you position the stones, as in lower grits on outside, one each of grits to the left and right of blade.  Keeps you from reaching over the blade.  I do this too, except my stones are just laying flat on the table.  Nice job there!
    Alan
    #34808
    driwash2
    • Topics: 7
    Very nice set-up.  What is the spacing from rod to rod?  I would like to make one like that also.
    #34838
    Roper
    Center to center is 1.5 inches…
    #34839
    Very similar to mine, where I too used a 1.5 inch spacing.  My pins are 1/4″ aluminum.  I never thought of the outside-to-inside progression.  Very clever.  I’ll have to try it.
    #34862
    That’s an awesome stand! Mine are still in a (Plano) box…
    #34865
    I can tell that you have a scientific background because you use an HP calculator with RPN input. You don’t see those every day.
    #34870
    Actually, I have two of them; an HP11C and an HP15C.  When HP came out with the HP35 back in the ’70’s, we had to learn RPN and now everyone who did so prefers it to the algebraic versions you get today.  The new calculators are so cheap that I’ve got at least 4 laying around the house and shop, but if one of the HP’s are within reach I’ll toss the new ones aside.  I think the HP’s go for a good price on EBay.
    #34873
    RPN, hahah. I had to learn that for certain calculations when do a computer science subject…
    #34959
    G-MAN
    What’s the story on the (non-WE) handles you use for your lapping films?
    #34963
    I guess this one’s for me.
    A long time ago, I decided to upgrade my handles to Oilite bronze bushings to reduce the amount of angular error.  It worked out really well, so since I had a fixture built for the conversion, I was converting everything I had.  This was before WE offered the glass platens, so I was kind of on the leading edge there.  I started out with maple, then Garolite (from McMaster) and finally ABS plastic.  The ABS turned out to be the nicest version, but then I had some problems with glass platens scratching the knives (couldn’t seem to get the edge polishing right), so I switched to brass and it seemed to be the cat’s ass.
    Since I don’t have a machine-shop level of equipment (I have wood-working gear) the level of accuracy I can achieve is limited, so I use the Variable Stone Thickness Adapters to hit exact angles.  The result, however, is that there is zero detectable slop between the rods and the handles and I can hit angles within < 0.1 degree.   Wipe the rods down with alcohol about once a month and they’re slicker than snail snot.
    I’ve shared the bushing conversion with a few other forum members, but I think it is beyond most of their abilities.  Cliff Curry  has what is probably an easier solution.  Clay has talked about selling an upgraded version of the handles, but nothing so far,
    #34966
    G-MAN
    Thanks for the detailed explanation!  The bushing conversion is beyond my abilities as well, but it is nice to learn about your cutting edge set-up.
    #35019
    I guess this one’s for me. A long time ago, I decided to upgrade my handles to Oilite bronze bushings to reduce the amount of angular error. It worked out really well, so since I had a fixture built for the conversion, I was converting everything I had. This was before WE offered the glass platens, so I was kind of on the leading edge there. I started out with maple, then Garolite (from McMaster) and finally ABS plastic. The ABS turned out to be the nicest version, but then I had some problems with glass platens scratching the knives (couldn’t seem to get the edge polishing right), so I switched to brass and it seemed to be the cat’s ass. Since I don’t have a machine-shop level of equipment (I have wood-working gear) the level of accuracy I can achieve is limited, so I use the Variable Stone Thickness Adapters to hit exact angles. The result, however, is that there is zero detectable slop between the rods and the handles and I can hit angles within < 0.1 degree. Wipe the rods down with alcohol about once a month and they’re slicker than snail snot. I’ve shared the bushing conversion with a few other forum members, but I think it is beyond most of their abilities. Cliff Curry has what is probably an easier solution. Clay has talked about selling an upgraded version of the handles, but nothing so far,
    Tom,
    We’re still working on this and will eventually release something…
    #35030
    Bill Kirkley
    • Topics: 19
    I noticed the discussion on HP calculators. For you iphone users there is an app for the HP 41 cx calculator. It is one of my favorite apps.
    Here is a link:
    http://alsoftiphone.com/i41CX/
