Tape for ceramic stones
Recent Forums Main Forum Sharpener and Accessory Maintenance Ceramic Stones Tape for ceramic stones
Viewing 15 posts - 1 through 15 (of 22 total)
  • #7827
    Mikedoh
    My ceramic stone fell off the platen last nite. Any suggestions on a good tape to stick it back on?
    TIA
    #7829
    TIA
    Micro-Fine or Superfine stone?
    #7837
    Mikedoh
    The 1.4 mic
    #7843
    The 1.4 mic
    It’s a pretty rare tape. We’ll send you some today.
    #7846
    Mikedoh
    Thank you Mr Allison
    Much appreciated
    #7847
    Fred Hermann
    • Topics: 30
    So get this…
    This weekend I let my ceramic stones soak to degrease for about 15 min. Stones fell out of the holder.
    Swore, even said bad words at myself…
    Used my daughters blow dryer to make sure everything was clean and dry, then used double back scotch tape to put them back.
    So far so good.
    Is there a reason to go buy some industrial double back tape? We used stuff in the Navy that could tape something to the outside of hte sub…now that was some tape…
    #7848
    So get this…
    So far so good.
    The tape we’re using for the Micro-Fine ceramics is different than the tape we use for the diamond plates. It’s formulated to adhere on one side to polypropylene and to ceramic on the other, but it doesn’t like water. The tape we use for the diamond plates doesn’t seem to mind water too badly but it doesn’t really stick to the ceramic. Elmer’s glue works really well…
    #7855
    Marion
    While probably not part of this problem, but polypropylene is in a group of plastics refered to as self lubricating, and most adhesives won’t stick to them relatively very well or for extended periods of time.
    #7856
    Geocyclist
    • Topics: 25
    Interesting thread. How are the Chosera’s adhered? Asking as these stone need to be soaked in water.
    #7877
    They’re attached to the aluminum blanks with glue and then the blanks are attached to the handles using the same tape we use for the diamond plates. I haven’t had any issues with them coming loose after getting wet.
    #7879
    I like to do weird experiments. (Well, this one was for a reason, but that’s another story.)
    Aluminium blanks (to which stones are attached) come loose from the paddles in water at about 35 degrees C (95 degrees F) if they are glued with “ordinary” hot glue.
    When attached with the 3M tape WE uses, they can stand water of about 70 degrees C (158 F) before they come loose.
    Even the Wicked Edge tape rules B).
    #7889
    Geocyclist
    • Topics: 25
    Enough said, it’s luke warm water for me.
    #7988
    Fred Hermann
    • Topics: 30
    I’ve had one of the stones fall off again, the other is solid still. So it appears junk 2 sided scotch tape works…for a while. I’m not going to assume this will be a permanent fix, but it’s interesting to see how long the one lasts. Once it falls off, I’ll compare and see if I can figure out why.
    Clay, if you see this, when buying a set of blank handles, do you provide some tape, or perhaps will you put the tape on the accessories list? Worst case you never sell much, so you don’t have to stock much, but we can compare and maybe find a local source. (just a thought)
    #8089
    D K
    I just had the exact same problem. Clay I sent you an email but I haven’t yet to get mine wet. I took it out of the box that i keep all my stones in and it just fell off. My sharpening had to wait. But on a positive note i received the updated arms and I’m super stoked about it!
    #8092
    Dustin, great about the arms, I’m sorry about the stone. We’ll get you some new tape. Elmer’s glue actually works best of all things I’ve tried :silly:
