CBW is exactly right… What I try to do is always make sure that the belly towards the tip of the knife stays as equal of a distance as possible from the pivot point of the base of my rod arms. for example… when I sharpen my para 2, i don’t follow the conventional wisdom of WE users… i actually use the flat spot at the base of the blade and angle it down so that way I end up with the tip being perpendicular to the rod arms.
You also can clamp the knife in the middle of the blade with an equal amount of the curvature of the edge all the way around, but you won’t be resting the spine on the depth pins…
That being said, if you have a large knife/blade (let’s say a junglas), then it will make the rear of the blade slightly more narrow than the tip if you are following the practice i mentioned above. What I have found is that making the tip perpendicular to the rod arms normally occurs when you clamp the knife blade into the vise in about the middle of the blade.
