It is not the 710, but has more of a recurve, at least from the photos of the 710 that I have found.
It is a Cold Steel Spartan . I did it with the stock diamonds, choseras and strops.
If you try edge leading strokes, you may have a bit of shaving of the edges on the Chosera stones on tight radius recurves, but nothing serious. If you go edge trailing, you should have no problems at all. With the minor recurve of the 710, it should be no problem either way… I would think.
I think that the Spartan came out very well.
