Diagnosing these are sometimes hard to pin down, so I’ll just throw a few things out..
S30V doesn’t polish well for me… always seems to have a misty or hazy look to it.
I think Phil is right, you should lower the angle. 21 almost 22 deg. seems a bit high. I stuck an unsharpened Griptilian in the clamp this a.m….. the edge was between 17-18 deg. Not to say yours couldn’t have been a higher angle… but I would double check this.
I’ve noted that S30V can sometimes develop a wire edge that is hard to detect until you do some actual cutting… it’s strong enough to survive light testing, but the edge will quickly dull or “roll” in use. It also won’t get as sharp (my guess is it slighty “bends away” from the abrasive as your sharpening or stropping). What I do to get rid of it, is, after sharpening but before stropping, is set a higher angle, 4-5 deg. per side, and lightly, with the finest stone or ceramic I have, make a couple of light edge leading strokes per side to get rid of it. Then return to the original sharpening angle make 1-2 light strokes, then strop or finish the blade however you want. The goal is not to create a microbevel… just clean up the edge.
Keep us posted!
