Pro Pack ll Mirror Edge
Recent Forums Main Forum Pro Pack ll Mirror Edge
Viewing 3 posts - 16 through 18 (of 18 total)
  • #41271
    dulledge
    • Topics: 12
    Another example of a wide, tooth-less, polished edge failing to cut as expected would be the skin on a tomato.  WTH?
    I guess that mirror edge is better to push across very tiny amounts of material like single hairs. If amount of material is more than a hair, then toothy edge is better.
    You will not saw tree trunk with very sharp mirror edge blade. Tomato skin is like a tree trunk comparing with tiny hair. You better saw it up with toothy edge.
    Another difference is direction. When material goes accross the blade like in chopping, then mirror straight edge is better. When material goes along the blade like in slicing, then toothy edge is better.
    #41272
    I may be wrong, but if I remember right, the preferred edge for the high level knife edge chopping competitions are mirrored polished edges.
    #41273
    dulledge
    • Topics: 12
    You are right. Thank you for pointing it. I was thinking about it too and has edited my previous post. When submitted edit, then read your post. Here is edited part I added above.
