Easiest way is to click “Add File” at the bottom of the message box…
then click “Insert” to insert the code into your post…
The photos won’t appear until you Submit the post.
(Now I just hope this worked!)
Edit 1: Hahaha and of course it didn’t. It did this the other day… for some reason it wouldn’t post the pics. After a while it worked again. So maybe it’s just broken right now.
Edit 2: AhHA! I figured out why it didn’t work… apparently the file size can’t be very large. I reduced them down, and now they posted.
The alternative is to host them yourself… like thru photobucket… then just insert the image code.
