Max thickness of WICKED EDGE GO ?
Recent Forums Main Forum Max thickness of WICKED EDGE GO ?
  • #40507
    Tyvain
    Hi,
    1/ What is the maximum thickness with the  WICKED EDGE GO ? (see if my fallkniven F1 can be sharpen)
    2/ Is it possible to sharpen a small hatchet ( maybe with an adaptor) ?
    Thank you
    #40511
    Greetings Tyvain, welcome to the forum!
    I would suggest emailing Wicked Edge with these questions. I don’t believe that anyone on the forum has received a production model of the GO yet.
    #40512
    There is no real limitation to blade thickness with the GO. With the stock screws, you can clamp blades up to 1/4″ or more. If you swap out the two vise screws with longer ones, you can clamp much thicker blades but you’ll need an angle gauge to determine the angle on the side of the Free Vise Jaw because the centerline of the blade will not be centered on the machine. The screws are 1/4-20 socket head cap screws.
    #40522
    Welcome to the forum, Tyvain. Always nice to see a fellow European here.
    #40570
    sksharp
    • Topics: 9
    Welcome Tyvain. Good questions.
