Low Angle
  • #29999
    mdwamp
    Hey folks. I just received my PP2 for Christmas. I’ve done 6 knives so far with each getting better that the previous. Having said that, I am having a problem with lower angles. I can’t seem to get anywhere close to 15 degrees. My angle meter show 19 and change and I can’t seem to get lower than that due to the stones hitting the vice. I have installed the included riser block. Any help would be appreciated.
    ~Mark
    #30001
    Mark, are you sharpening slip joints or narrow blades? if so that’s what’s causing the issue. You need the Tormek small knife jig and you will be all set.
    #30002
    mdwamp
    Narrow blades. I attempted a buck 512.  Thanks for the reply. I’ll have to order one.
    M
