Loosening adhesive advice
Recent Forums Main Forum Welcome Mat Loosening adhesive advice
  • #10407
    Mikedoh
    I’d like to take the steel platens off of my new blank handles/platen combo.
    Didn’t realize they were already attached.
    Thought I’d check and see if anyone had any info on this befor I started in.
    Thanks
    #10408
    Thanks
    Run them under hot water to soften the tape, then use a putty knife to get under the metal. Just use a corner of the blade and gently push it under, I usually start at the end in one of the corners. Once it’s in position, pry up a little and gently work your way down the handle. It’s not easy since the adhesive is so strong. Being patient with it pays off.
    #10413
    Thanks
    Now I’m curious what you’re going to do with them…
    Wonder if a hair dryer or heat gun would work too?
    #10416
    Hair dryer yes. There might be a danger of melting the plastic with a heat gun. Using hot water works well because because it softens the tape and makes it pliable and also gets in between the tape and the metal once you start prying.
    #10452
    Mikedoh
    Hot water worked well. Used a 5 in 1 tool to remove the platen. A bit stouter than a putty knife.
    Cbwx– wanted access to the round recesses in the handle for magnet placement.
