I have been lent this knife to try and clean it up. The tip originally broke off. The owner reground it himself if i am not mistaken.
You can see it needs a bit of love. my initial thoughts are to simply Take the whole edge down, level it out, and reshape the whole blade. I don’t see another way to really salvage it as a consistent chefs knife other wise.
Any thoughts?
It honestly doesn’t look all that bad from what I see in the photos. In terms of leveling out the edge, I’d recommend Josh’s method of de-stressing the edge from heel to tip.
Scrub to about 2 minutes in and you’ll see what I’m talking about.
ah Ok, I do do that. How ever on this knife it has a concave curve inward just past the handle, then a convex curve outward towards the belly. At the belly it is almost flat then you end up with a second convex belly near the tip. That is what i would like to remove.
What you are describing is restoring the factory geometry of the blade. i have to do this a lot w/ many of the large kitchen knives I get in… basically putting a nice curve in the entire blade through the heel so that way you have full contact w/ the cutting board all the way through the rocking motion from heel to tip.
You either have a lot of grinding to do w/ your 50 grit stones or you need to get a belt sander lol…
Funny seeing that knife, I have a 26 year old set of balanced plus Gerbers… wedding set. That exact chefs knife has big meaning for us, Lotta miles. Definitely agree it’s screaming for a belt sand fix. WE after that. Thanks for the pic
