Thought I’d share a couple of photos… I picked up one of the Vacuum Base vises at Lowe’s (mentioned elsewhere) and decided to use for mounting the Field and Sport unit. Turns out very simple… just unscrew the baseplate that holds the vise, take out the center bolt, add a washer (so the bolt won’t go thru the hole on the bottom of the F and S unit), and bolt it down!
(Knife is a Kershaw Echelon 1880).
When done, it comes apart and fits nicely in the toolbox I had, along with other stones, etc.
Holds well and works well! Piece of cake! :side:
