DIY: Repeatablity Tool
Recent Forums Main Forum Techniques and Sharpening Strategies DIY: Repeatablity Tool
Viewing 16 post (of 16 total)
  • #12222
    Larry Mingus
    If you have the 10.5″ images that would be great. The triangle that I have it about 13″ on the long side 12″ on the vertical side.. I can always index the scale from a known point and go from there.
    I am thinking that I might laminate it… for durability. What did you use to stick the scale on to the triangle?
    I’m busy right now but I’ll try to get to it ASAP
    I used Scotch double sided poster tape and then put a layer of Scotch satin gift wrap tape over the top, it worked great. I cut the paper rule to match the width of the tape.
    I thought about laminating it but took the easy way out, too lazy to drag out the laminator. 😉
