Diamond Block Bore Parallelism
Recent › Forums › Main Forum › Off Topic › Diamond Block Bore Parallelism
- This topic has 6 replies, 4 voices, and was last updated 07/08/2014 at 3:09 am by
Josh.
07/06/2014 at 3:23 am #19360
As some of you know, I made a batch (actually, several batches) of glass-platen blocks using bronze bushings instead of a plain bore-hole as guides on the slide rods. I really liked the feel of the bushings and they are clearly more precise than the clearance hole which appears to be molded into the thermoplastic WE blocks. I wanted to come up with a method of converting my WE blocks to the bronze bushings, but at the cost of $65 per set, I wasn’t going to take the chance of ruining a set in the attempt.
Then I pretty much wrecked one of my 400 grit stones on a ceramic knife and I had to buy a set of replacements. This, of course, meant I had an extra pair of blocks on which to experiment. I proceeded to make a fixture which would clamp the block so that a drill press (or in my case, a plunge router) would bore a pocket in parallel alignment with one face and one side.
Bad news/good news. Bad news is the thermoplastic doesn’t like high speed tools. It melts easily and therefor isn’t very machinable with woodworking tools. After the pockets were machined, I clearanced the 1/4″ thru-bores by drilling them out to 9/32″. This would prevent any misalignment of the bore from interfering with the rod in the new bushings. The good news is that the pockets worked great anyway. The bushings are a thumb-press fit and parallel to the reference face within 0.004″.
This was good enough that I decided to do it on my 800/1000 blocks, because I knew that one of them was out of whack. When flipping the one stone from 800 to 1000, the SWAT plate showed a significant difference. So I pulled the trigger and refitted both stones to the bronze bushings. Again, great success. The bushings are parallel to the 800 grit face within 0.004″, maybe better.
But this time, when I set the SWAT plate for the 800 and then flipped the stone to the 1000 grit side, the difference was almost twice what it had been. Wow! I went back to my granite plate and checked parallelism to the 1000 grit side and found an error of .032″ from one end to the other. This made me look closely at the block and I was stunned to see that the 1000 grit platen was not seated properly in the block. It was about 0.025″ offset to one end and therefor was sitting up on the rim of the yellow plastic base.
More than anything, this is embarrassing for me, as I’ve been taking repeated digital caliper readings from these blocks as I tried to duplicate the dimensions with my glass blocks. Apparently I never measured this particular end. If you visually examined the platens, the ends looked absolutely normal, but when I looked at the width of the platen edge showing above the yellow plastic, it was clearly wider at one end than the other. I should have seen it. I’m sure I did see it, but it didn’t register.
At the end of this post are a couple of photos. The first shows a scalpel inserted under the platen end, where it hadn’t been properly glued. Sorry for the poor focus. The second shows my fix. I used a hacksaw blade to cut off the end of the yellow plastic so the platen could be glued down properly. I squirted super glue under the platen and clamped it in my wood vise for a few minutes. Worked great. Parallelism is now beautiful.
Parallelism between the rod-bore and the stone faces is important. The fault in the block described here resulted in 0.25 degrees of change in the stone’s angle when bottomed on the rod and resting against the vise and when the bottom edge of the stone was raised to the lip of the vise. Before my modifications, the error would have been at least one half of that for both sides and I have been using that stone for three years without noticing the error. Again, if the rod isn’t parallel to the face, the angle will change as you raise and lower the block relative to the edge.
The moral of this story is that you should closely examine your blocks to make sure the platens are seated properly in their plastic bases. If you have an accurate means of measuring for parallelism, do so. I place the stone face-down on a flat surface with a rod in the bore. Measure the distance from the top of the rod to the flat surface. Do it for both ends. Then flip the block to the other face and do the same. If you find a difference that seems large, check with your AngleCube to see if that error changes the angle as the block is moved from bottom to top of stroke.
No, I won’t be asking for a replacement, even though Clay would probably offer one. I’ve gotten three years of use out of it and in my book, that means the warranty has expired. Besides, the fix took me less than 15 minutes.
Attachments:07/06/2014 at 12:27 pm #19361The 0.25 degree error discussed above was “as measured” with my AngleCube. Later this evening I checked that against the measured parallelism error, math-wise.
My Navy trig class lasted four hours, but “Suzie Can’t Tell, Oscar/Had A/Hunk Of/A__” still works. The Opposite side divided by the Adjacent side equals the Tangent of angle theta. In my case, 0.032 / 5.75 = 0.0056. The Arctan of 0.0056 is 0.32 degrees.
So a bore misalignment or a dimensional error of 0.010″ from one end to the other would cause an angle change of 0.1 degrees as the block was moved vertically along the rod.
I really don’t know if 0.1 degree error is all that noticeable at an edge, but since I’ve mastered the Variable Stone Thickness Adapter, it’s readily apparent in the settings. Especially with the glass platens and bronze bushings, as you can easily feel in the micro-adjust screws when the face of the block makes flush contact with the SWAT face.
The main thing to take from this is to closely check your platens to make sure they’re properly seated in their blocks.
07/07/2014 at 7:16 am #19370Thanks for posting this Tom. I have noticed that some of mine aren’t seated really perfectly flat, but I haven’t taken enough time to deal with it. This will probably give me the motivation I need to check!
Keep us posted how you like your new bushings in your stock paddles! That’s pretty sweet.
07/07/2014 at 7:44 am #19372Yes, the bushings look very good. Please keep us posted!
07/07/2014 at 12:16 pm #19376The bushings move the Wicked Edge system up to a whole new level of precision. They feel rock solid when in use and for me there’s no going back.
Because the bushings limit how far up the rod you can move the stone before the tip of the rod slips out of the top bushing, you need longer rods. I made mine from steel rod stock from McMaster. Bushings are meant to run on polished rods and regular bar stock varies in diameter. I had to do a little polishing on my 400-grit cotton wheel to eliminate tight spots. With a few spots, there was apparently an alignment issue and I had to loosen up the bushing to accommodate the cheap steel. The alignment of the bushing bore isn’t so important. It’s the location of the aperture relative to the face of the stone, so using a hand-drill to loosen up the fit by wobbling it around in the bushing works just fine. It doesn’t significantly loosen the bushing fit.
I bought a 4 ft length of stainless only to find it was even less perfect. And threading the end for 1/4-28 with a hand die is a bitch. Even the regular steel was a bitch. When I tried to thread a section of soft aluminum rod, the torque applied to the die twisted the rod all the way back to the vise. Maybe Clay would sell us longer rods pre-threaded from their inventory?
07/08/2014 at 1:10 am #19380Hey Tom,
I think I understand what you did, how did you do it? Did you just drill holes for the bushings and press in? How did you drill more accurately than the original holes? Or is you improvement due to less play in the bushings vs. a more accurate/parallel hole drilled?
In any case your work looks good.
07/08/2014 at 3:09 am #19383Tom, get with Bob at oldawan…. he can get the longer ones if you need them. I got my 10″ ones from him, can’t remember price though. Of course, it will be cheaper if you can do it yourself =)
I am still not understanding how it is not important to get the hole drilled that accurately… if you have the top hole and bottom hole in the paddle crooked then your whole stone face will be crooked and not flat. could you explain more? thanks!
