When you put it back together, make sure the crank handle is at the front or you’ll be doing it all over. Doh! Really, aside from putting the cam follower on the wrong end of the spring, that’s about the only thing that you can get wrong and before you ask, yes, I did it. The crank handle. Once.
As long as you’re trying this, you might consider one of the tricks users have tried to keep the cam mechanism clean. I used some HVAC foil tape as shown in the photo below. Any kind of tape will do. I put a little dab of white lithium grease on the cam before I sealed it up.
