So are you saying that we should move our ceramics in one degree to keep the same angle as the diamonds? I dont have an angle cube so any help is appreciated.
Lucky
I am seeing 1 degree, but you will want to test it on your system with your stones. After you run the 1000 grit diamonds, color the bevel and use the 1200 ceramic, and see if the whole bevel is hit, then move the arms in or out, and color the bevel and try again, until you hit the whole bevel. Just make sure you are going all the way to the edge because if it looks good but doesnt cut it is a hammer, not a knife.
