Cheese Knife
Recent Forums Main Forum Welcome Mat Cheese Knife
  • #52316
    Michael Blakley
    • Topics: 29
    I have a cheese knife that I want to sharpen.  It’s from wandpdesign.com.
    I have contacted their customer service department to find out the degree at which the knife is factory sharpened, but they have yet to provide me a number, but they are trying.
    The knife blade is 8 cm long (3 inches and 3/16th).  The bevel itself is maybe a millimeter wide.  It’s so short I can’t feel the blade rocking when I lay it on a flat table.
    Let’s say that the manufacturer can’t come up with a answer for me, how do I measure the existing bevel so I can avoid screwing up the profile of the cheese knife?
    Here’s a link to the knife:
    https://wandpdesign.com/collections/kitchen-and-home/products/the-cheese-knife
    Thanks!!
    Michael
    #52317
    • Topics: 95
    Michael, after doing a little reading up on the web what makes a good cheese knife,  nothing indicates sharpness as a needed quality.  I found that different style knives are used with different cheeses.  That being said,  I’d probably start simply with a strop on your knife.  I’d expect refining and smoothing the edge will probably help contribute to it’s effectiveness.
    #52318
    Brewbear
    • Topics: 7
    When in doubt, I start with a Sharpie and a very fine grit stone. Cover the cutting edge of the blade with the sharpie and take a light pass with the stone. Check and see if the marker was removed, adjust angle as needed.
    #52326
    Michael Blakley
    • Topics: 29
    Good news.
    The folks at Customer Service got back in touch with me.  They gave me the information and actually included a drawing so as to remove doubt!  It’s 14° to 17° on either side.  So, I”m going to set my WE at 15° when it comes time to sharpen it.
    Michael
    #52332
    Michael Blakley
    • Topics: 29
    The shiny vertical line is the bevel.  I’m holding the knife against the mm portion of a metal ruler.  So it looks to me like the bevel is a millimeter from apex to the side of the blade.
    With most knives I can figure out the angle of the bevel by rocking the knife on a hard flat surface and feel where the bevel is lying flat.  Then a protractor measures that angle for me. But this this tiny bevel, I could not feel any rocking or fulcrum at all.
