UPDATE – Kyle and the boys at WEP hooked me up. new stones arrived today and are perfect. can’t wait to get them going. THANKS GUYS!
this thread is a spin off of my into thread i started the other day. I realize there was a subsection for these stones after i started my initial thread
one problem i have run into already of which I’m certainly displeased with. about 6 knives in my 1600 stone came off the platen. appears the hot glue didn’t like the stone all that much. i took notice to my other 1200/1600 stone and the 1600 is becoming “soft” in the platen as well.
granted I wasn’t too happy after spending the considerable amount of coin on this system. any ideas where to go to have this problem fixed? was / is this a common issue and something i need to be concerned about with WEPS stones?
another issue with the same stones, the 1600 stones themselves seem “streaky” and inherently not flat. after a number if knives all i have is some dark think black lines on the stone letting me to believe their are inconsistent ridges and not allowing a full flat contact on the blade itself.
here are some pictures for you guys
as you can see on the stone itself, the high ridges where the black lines are would lead me to believe that those are the high points and the majority of the contact points on the stones. both are doing it and are the only stones (ceramics) that i have that are doing it. I will also add when running these on the blade they feel gritty and bumpy as i can feel certain points of the ceramics catch harder on the blade than other areas on the specific stone.
