Blades without sharpening notches
Recent Forums Main Forum Blades without sharpening notches
  • #34671
    Mjcollier
    • Topics: 13
    What’s the best way to sharpen that last 3/16 of an inch that can’t be reached with the stones?
    Do I need to grind off  the plastic so I can get the stone right up to the ricasso (I think that’s the proper term).
    Thanks for any help.
    #34672
    Anonymous
    Inactive
    That’s what I did. Just one side of each. The barrel sandpaper tip on the dremel worked best for me.  Wear eye protection and watch out for that hot plastic when ur grinding.
    #34678
    Grinding off the plastic is one way. Another way, which I did, is to make a sharpening notch in the knife (I did this on a Spyderco Tenacious). And of course you could settle for a little unsharpened part of the blade. But really, I don’t understand why they design such knives. Definitely not with use/sharpening in mind.
