Wicked Edge custom rods/paddles
Which tight tolerance rod are you referring to? I may get some of the .375 to fit out my older gen rod arms I still have and use… I will have to measure these rods… I didn’t want to get too long if I can help it so the tips don’t bump into each other; do you find this is ever an issue? I’m guessing not! :wink:
That is amazing about the gun drilling!! Wow! I know on these holes I had a longer drill bit (probably 7" long) new, that I tried first had much more wobble than the Norseman shorter bit did. So I know I had some issues w/ that but it is probably more that I need longer bushings maybe than anything.
Yes I believe he used commercial available drill rod! And you have it exactly correct, the one end was drilled and tapped and a stud installed =) Very good eye!!! Are you a machinist too Victor?
Well I ran into some issues making paddles w/ stock holes on them w/ tight tolerances… for some reason my drill bit is drifting in the hole a bit or something and causing a bend. That and the stock rods being able to be bent or not perfectly straight can cause issues w/ tight tolerances… But this threw me on another track… bore out the hole enough to where this doesn’t matter and then install linear bearings as bushings in each end. These are self adjusting so any curvature in the rods won’t make a difference. They are extremely tight tolerances w/ the stock rods with zero play and yet still smooth =) The key is to have rods long enough that the paddles won’t come off of the ends.
Would be sweet to mill pockets for magnets into the faces and then just switch out stones/lapping films/strops all backed w/ a magnetic steel. Still trying to figure this out…
Josh, I supposed you did not consult with your Machinist friend on how to drill a concentric hole doing the Machinist way?
I just asked him this morning… he said try peck drilling I think was the term… removing only 1/16 at a time. Do you have any more tips my friend?
Peck drilling is new term for me..learn something new everyday! I get the picture!
Basic skills such as drilling appears to be simple…truth of the matter is - the more your think you know…the more you realized how little you really know!
If I remember correctly, peck drilling is a process of drilling only a very short time before backing the drill out then repeating the process over and over.
Gun drilling, a process for drilling long, straight holes, uses a bit which is not a twist drill. The bit has a single groove, running in a straight line from tip to shank. The tip has a single carbide cutter and a small hole bored from one end to the other. Coolant is injected under pressure to drive the chips out of the hole and up the groove. Just above the cutting end is a short section of the drill which is full diameter. This holds the bit on its axis, reducing any tendency to drift off-center.
