WEPS settings for PARA 2 S30V
Hi all,
Could someone share what would be the best settings for a PARA 2. I really like the original edge from spyderco but I think its time for a WEP profile. Most importantly, I need to retain the pointy end of the PARA 2.
Thanks in advance.
I use this method w/ an angle cube instead of the stock depth settings - I never use those any more. I also use the sharpie method in conjunction w/ this a LOT. To maintain the point keep more pressure on your thumbs than your fingers (if the knife is pointing away from you) and you won’t roll around that tip.
I recommend reprofiling to 15 dps, try it, and if you have any issues throw on a microbevel. I’m gonna push my EDC folder (ZT 0561) down to 10 dps soon (w/ a microbevel likely).
https://www.youtube.com/watch?v=2T0wQDHKMR0
Thanks for the tip on ‘how not to roll the tip’ and the very informative video.
Yup, I too was very happy when I first got the WEPS. By just following the simple procedures, the results were outstanding. I trained on all my kitchen knives and made my wife very very happy. I think I’ll invest in the angle cube too. Can’t really rely on the scale markings as different blades do differ and angles do change from knife to knife.
If setup correctly, no more uneven bevels. All I need is more practice. Probably head down to my parents and sharpen their knives too :slight_smile:
Thanks for the great video. I had used tape and tried to line the edge of the tape with my knife edge, not so easy. Brilliant idea to mark a line on the tape. I have my first Para 2o on the way so perfect timing with the video, especially showing how you tilt it.
The point of even finger/thumb pressure is a great tip. I have not really thought about that too much. I sharpen sitting on the sofa with the WE on a table. The last several knives have had the tip on one side more acute than the other. My bevel on the main flat of the blade is pretty even side to side. I think sitting is part of my problem (I often rest my elbow on my leg) but that may also affect my finger/thumb hold.
Jumpstat, use the sharpie a lot. One thing I learned the hard way is if you don’t get the edge right in the beginning don’t go any further. It won’t get better with the smaller grit stones. Plus the problem is probably in your setup. So keep checking with the sharpie until you are satisfied. After that I continue checking as I use the 100’s.
