WEPS Dimensions
I am away from home and need to find out the measurements (Height/Width/Depth) of the WEPS with the PP2 upgrade. If anyone can help I would greatly appreciate it. Thanks.
What dimensions do you need, MesaCranker?
I made some measurements on my PP2 WE.
[ul]
[li]- The vice is about 14 cm high including the low angle adapter.[/li]
[li]- The LAA itself is about 2.5 cm high[/li]
[li]- The stock rods are about 23 cm long, when measured up till and including the ball joints[/li]
[li]- The bar with the angle marks is about 28 cm long[/li]
[li]- The blue base that holds the vice is about 28 cm long[/li]
[li]- I don’t know the measurements for the entire bases are, since I made my own base[/li]
[/ul]
Pro-Pack II without Granite Base
11" (degree bar) x 5-3/4" (blue base) x 5-5/8" (height to top of Vise Jaw)
Weight (without stones) approx 3 lbs
Pro-Pack II with Granite Base
12" x 10" x 6-3/4"
Weight (without stones) approx 18 lbs
Shipping dimensions and weight
14"x12"x12"
Weight (with stones) 25 lbs
