My we 130 vice has developed a clicking noise when releasing the knife from the jaws. I know there was a topic on this in the forum when this type vice first came out but I can’t find the article. Does anyone have a cure for this?
How old is your WE130 James? When did you get it? When you release the cam lever by rotating it to the left do the jaws spring open and stay open?
I found the article I was looking for from graphite. The cam follower was a little tight. I sanded it lightly and now all is smooth.
Thank to all for the help.
Reviving this subject due to my WE130 making the clicking noise James described. When closing the vise at approximately 3/4 of the way down the vise makes this click or more like a pop in my case. I tried the search feature but I’m not having much luck finding the thread James mentioned. Need some help finding the thread by graphite or some assistance in troubleshooting the issue. Any help is much appreciated.
This is the Wicked Edge Forum thread where the clicking vice was discussed.
Here is the PDF instructions to disassembly and clean the Gen 3 vise:
WEClampCleaning.pdf
Hope this helps.
Greatly appreciated MarcH. I’ll give it a go tomorrow and see if it solves my issue.
Took my vise apart this morning and cleaned it up. Everything is working well, (very smooth). If I have the problem again I’ll contact Wicked Edge. Thanks for the help folks.
Duke, I find my vises may get a little noisy or sticky with a lot of use, over time. I just do what you did, and break them down and clean and lubricate the parts with a dry wax lubricant suitable for bicycle chains and derailleurs. I use the same lubricant on the guide rod ball ends after wiping them clean with a dry towel. This I do simply for regular maintenance.
