Vintage Straight Razor Restorations
I was pretty excited and had to share. Even tho the work wasn’t don’t directly on the WE, it wouldn’t have been possible without all that I’ve learned from this forum over the past year.
Work was completed using a combination of a 1x30 sander with +1000 grit belts, a buffer with coarse, medium, & fine wheels, a really cool fiberglass scratch pen tool for the nooks n crannies, and all the sharpening was done with micron films on glass. The concave blade face was resurfaced using a hand drill chucked with a large sandpaper wrapped wooden dowel.
Because they were so old and thin I couldnt refinish the blade face as far as I would have liked to remove all the “spider web” corrosion but I was totally surprised how well they came back to life!
Closeups of before and after with with fiberglass pen. $7 on amazon.
And finally in a bold move I decided to test them on myself. First ever razor sharpening so why not make it a first ever straight razor shave(after watching youtube ofcourse). :cheer:
Smooth baby smoooooth! :whistle:
Really nice, Cliff! My barber (who doubles as a straight razor seller) does the same. He uses a dremel and of course some stones.
I assume you had to take the knife apart?
Thanks Mark :slight_smile:
I didn’t pop the pins to disassemble the scales for a couple reasons. Mostly I was too chicken that I’d damage them. It was my first go around and I’ve never removed pins like this before, didn’t have replacement pin material on hand, and most importantly I’ve read that especially with older ones the scales can break from getting brittle or something.
This was for a customer so I chose to error way on the side of caution since these were his grandfathers. I’m thinking I’ll pick up a used one for myself to experiment with in the future.
I was really torn because I wanted to take it apart so bad for a full polish but couldn’t risk damaging irreplaceable history in the existing scales.
How then did you remove the rust around the pin? The razor looks great everywhere.
Very nice Cliff!! Looks awesome!!
I have a razor that I have to re-pin… gonna be interesting, I will try to post up pics. It’s my own razor so no fear of something going wrong hehe. I am going to be putting in a removeable pivot this time though. For some reason it’s missing a pivot washer and the tension isn’t adjusted correctly.
[quote quote=“razoredgeknives” post=24261]
I have a razor that I have to re-pin… gonna be interesting, I will try to post up pics. It’s my own razor so no fear of something going wrong hehe. [/quote]
Please do! I also have my own straight razor that requires refinishing. The only thing that’s holding me back is that I think it also requires removing the pin.
I’ve watched a few videos on re-pinning. It seems straight forward enough with a light touch of the ball peen hammer and proper pins & washers?
Delicate work for sure! :dry:
Killer job Cliff!
Came back as good as it can given the pitting and age.
Nice detail work.
