I notice the right hand side of the vice moves to the right and slightly out of the blue base when the lower screw is tightened. The lower right hand side is not threaded like the top and that matches drawing in the manual, so it pushes the right vice base to the right when tightened. I did not note this initially and started looking closer when I noted I often could not get similar angle settings with the presets when using the angle cube. I take it this movement to the right is normal?
Will
