Since the Variable Stone Thickness Adapter (VSTA) first became available, I’ve seen two or three requests for explanations or demonstration of how it works. I haven’t seen a serious response so far, and since I’ve settled in on using it now with every stone (grit) change, I figured I might as well offer my method as an example.
First, in full disclosure, I have to state that I’ve converted all of my Wicked Edge stones to Bronze Bushings. I’ve counterbored the ends to 3/8” diameter, about ½” deep and reamed out the factory bores to 5/16”. The bushings, which I’ve epoxied in place are from McMaster-Carr, part number 6338K412 , as seen on their web page http://www.mcmaster.com/#catalog/120/1142/=syghhp.
As installed, my converted stone assemblies have almost zero detectable angular backlash, as compared to the stock bores, which I’ve measured to have angular backlashes anywhere from 0.1 to 0.3 degrees . It’s possible that the tighter tolerance in my stones have pushed me to full-time use of the VSTA’s, as the variability in the thickness of my stones is more easily seen in the form of angular errors in my scratch patterns.
STEP 1:
When using the Variable Stone Thickness Adapters, you start with a beginning or reference stone, set to a beginning or target angle. You then set the VSTA’s to match your reference stones as closely as possible. For instance, I will set the beginning angle(s) as desired or by using the Sharpie method to find the sweet spot, using my 1000-grit diamond stones. This is the highest grit which has a ferrite substrate, which will hold my magnetic-base AngleCube. The high grit is to reduce the severity of any scratches resulting from carelessness in the setup process. To provide adequate adjustment range for the micro-adjust screws, you’ll want to have them showing about three turns of thread between the hex-nut on the ball joint and the face of the mounting block after the initial angle adjustment. See the photo below:
STEP 2:
The next step is to move the VSTA into position against the face of the reference stone. I slide the VSTA into position against the face of the stone and then pinch the center of the stone against the inside face of the VSTA. See the photo below. When I feel the VSTA is in a comfortable position, I tighten the set screw, locking the VSTA onto the degree-bar. Now, the VSTA is the fixed reference, and all subsequent micro-adjustments are made to it. You don’t tamper with the VSTA’s position until the knife is done or you’ve decided to change the angle, as when adding additional bevels.
STEP 3:
Now that the VSTA is fixed in position, you switch to your starting grit stones and make the appropriate micro-adjustments to match the stone to the VSTA. I reach around the vise with my opposite hand and pinch the top end of the stone against the face of the VSTA. Hold the rod just above the stone against the VSTA with your thumb and index finger. See the photo below. While holding the stone fairly tightly against the VSTA, turn the micro-adjust OUT (ccw) until you see daylight between the base of the stone and the near face of the VSTA.
STEP 4:
Next, without releasing the holding force at the top of the stone, slowly turn the micro-adjust screw IN (cw) until you feel resistance. This will happen when the bottom end of the stone makes contact with the near face of the VSTA. This means that if the bore is parallel to the face of the stone, the rod is now parallel to the face of the VSTA and you are ready to begin stoning.
Of course, you do STEP 1 and 2 for both left and right sides and you execute STEPs 3 and 4 for each change in stone faces – yes, even when turning a block from the coarse face to the fine face. For most stones, there will be a very small change in the final micro-adjust screw, but there are examples of substantial change.
ADDITIONAL NOTES:
If this seems confusing, I’m sorry I didn’t explain more clearly. This exercise is really quite simple, takes only a few seconds per side and easily becomes routine. Once I got the process down to a level of consistency, it was readily apparent that it improved my sharpening process. I had several stones which had never seemed to work quite right. This explained why and fixed the problem for good.
It helps to have a micro-adjust hex-wrench for each side. I have the screwdriver type, but a short wrench which stays put in the micro-adjust socket would be even better.
Making frequent changes in the micro-adjust screws would bugger up the threads if you had the set screws sitting metal-on-metal. I cut a short (maybe 3/16”) length of wire insulation and compressed it against the threads of the micro-adjust with the set screw. I roughly polished the end of the set screws flat, so they wouldn’t twist the plastic out of position. Once the plastic is compressed to a solid, it will assume the shape of the threads and act as a friction brake – think Nylok. It doesn’t have to be a substantial amount of braking force, as you’ll be adjusting the screw again in a few minutes anyway. It probably ain’t gonna move much anyway and you don’t want to bugger the threads.
If you’re wondering what the deal is, the photos were taken with much of the unnecessary hardware removed for clarity.
Further info on how I converted my WE stone blocks available on request.
OK guys… the board is open for disclosure of your methods. What do you do different?
