trouble with 50/80 grit stones.
I found found the 50/80 stones a bit intimidating when first unboxing. Luckily I had some re-profiling to do on basic kitchen knives similar to Eric above.
After just a few hours of a fairly intense medium duty workout they settled down and I wouldn’t think of doing major reshaping/repair without them. Granted I have not tried redoing a zdp-189 with them but Im pretty sure I used them when I took my s30v spyderco down to 12dps. I probably just used them for material removal and kept away from the apex when I did it.
Its a tool that has its place in my kit. I use it to grind shoulders, thin secondary bevels and such. I follow that up with a new pair of 100/200 to remove the heavy scratches, refine the bevel shape and almost take it to apex, then use a heavily worn old pair of 100/200 to hit the apex before running up the scale.
Aloha,
Cliff
tcmeyer,
Thank you for idea.
