To the guy from Melbourne (Mountain Man?)
I accidentally deleted your introduction topic. I am really sorry about that. I pressed the wrong button on a tablet and… your topic was deleted. Not even an “Are you sure? Yes/no” question.
It is not the most charming way to say welcome, but: welcome! You’ve just joined a very helpful bunch of guys and if there’s anything you want to know, please let us know. You wrote you don’t have a WEPS (yet), so if there’s any general sharpening questions you have, they’re very welcome. And buying advice… we all have experience with the WEPS, but many of us also with plain stones or other systems.
So as I learned when I lived in Australia: welcome, mate! I also learned “no worries, mate”, but perhaps I am not the right one to say so right now…
Gib, I am also sorry I deleted your welcome reply by accident.
That’d be me. Darren from Melbourne, Australia.
It’s all good Mark, no worries mate. :slight_smile:
My post was just a basic introduction, and I explained that my main purpose for getting a WEPS would be to sharpen my filleting knives. It looks like a great system, but my concern was whether or not it would be the best system for sharpening flexible filleting knives.
I got an email notification of Gibs reply, so I did get to see his response. Thanks Gib.
SO no harm done. I’m looking forward to reading the threads here and learning as much as I can.
Cheers
Darren.
Hi Darren:
I did about eight filet knives over the holidays, along with about thirty more utility knives after I invited a friend to bring his knives over for sharpening. Turned out he had a batch, his son had a batch, his grandson had a batch, his wife had a batch, and then, to top it off, he came around with a batch from his cottage up in the UP. What are friends for?
The filet knives were all in the 150 - 170mm range and all J. Marttiini (Finnish) design. Several were the good quality Rapalas. I clamp them up at the very top edge of the vise, with only about two inches of the tip extending past the vise. These limits the flexibility of the tip , but when I concentrate on the forward part of the blade, I use my opposite index finger to “stiffen” the blade. As I work on the handle end, I hold the handle - again with the opposite hand - to resist movement. Yes, I choose to work one side at a time and this helps a lot.
I should mention that the WEPS comes with a rod you can use to hold the tip more rigidly. I looked in my photo folder and found one showing the rod used on a filet knife. On the better filet knives, I’ve found the slot is too narrow for the blade. Unfortunately, there’s a lot of clutter in the background.
If you look around this forum enough, you’ll find a couple of gadgets you can add to hold the blades beyond the vise. Someone is sure to provide the link here, now that I’ve mentioned it.
I should mention that the Rapalas have a heavier spine and a back-bevel (primary bevel) of only about 12 degrees. I polished these up, then added a microbevel of 18 dps. On the cheaper knives (see the one in the photo) I put on a 15 dps back-bevel and the 18 dps microbevel.
Of all the knives I’ve sharpened on my WEPS in the last three plus years, the filet knives are the ones that draw the most blood. Most knives will just scratch you as you pass by the tip. Filet knives tend to stick you and then follow you along to finish the job.
haha - sounds like fun.
Thanks for the reply.
I have a couple of martinis, the shorter of which looks very similar to the one pictured. It’s a great little filleting knive on smaller fish, but I use it mostly for removing the ribcage from flathead. One of our tastiest fish from Australia, and in particular Port Phillip Bay in Melbourne which is where I do most of my fishing.
I’ve just made contact with a guy not too far from me who has the basic kit. I’ll be catching up with him soon to give the system a try on the fillet knives. If that all goes well I anticipate the purchase of a Pro Pack II in the not to distant future.
Thanks again.
