I cut lots of cardboard with my Spyderco Delica 4. I often like to cut with the tip, but I have a nasty habit of overzealously dragging the point of the tip across the cement. This inevitably leads to needing a repair!
Technique #1
The first time I repaired the tip, I did it similar to a basic reprofile. Using the 100/200 stones, I layed them flat against the bevel, with about 1/4 of the stone extending past the tip, and “scrubbed.” By paying attention to holding the stone flush against the bevel, I could ground down the metal without rounding off the point. I also made sure to run the stones across the whole length of the blade every so often just to maintain its original shape.
I quickly learned that the 100/200 stones were overkill – is in overkilling the point by tearing it to shredsl! Now I typically start at 400 or 600 grit, depending on the circumstances. I need something coarse enough to remove metal, but fine enough to create/maintain a point.
I have done this about 6 or 7 times. I always improve the point a lot, but when viewed with a 60x loupe, I can see deformation like chipping or rounding. I simply could not achieve a satisfyingly apexed point. So I decided to try something new.
Technique #2
Call this the Brute Force method… aka “Are You Kidding Me?” To me, it’s just doing the obvious – wrecking the edge completely! (Well, not completely, just near the tip.)
I removed the 600 grit stone from the control arm, and laid it flat against the apex of the knife’s edge (the knife is mounted normally in the WE, and the stone is parallel to the table). I “biased” my pressure toward the tip because I didn’t want to flatten more edge than I had to. And so I basically ground a new point with a few (very careful) brushes forward. I used the loupe to verify I had created a new – very finely apexed – point. Now I put the 600 stone back on the control arm, and I return to sharpening as usual. Okay, yeah, I killed my edge, so “as usual” isn’t quite right, but there it is.
A few caveats. I removed too much metal when creating the point so I probably would try 800 grit next time. I also believe I will eventually deform the shape of the blade. (Good thing I like Tantos! :D) Obviously this is a major drawback, and I will need to find an answer if I want to continue with this method.
I’m pretty much a sharpening newbie (in case purposefully wrecking my edge didn’t make that clear!). So I be love to hear some comments on what I’ve tried here, and especially if there are other suggestions!
-Pie
