Sorry guys, but I have a real problem picking up on what you’re seeing in the clamp set-up in the last photo. I thought I could see that the opening between the two sides was wider at the bottom than the top, so I blew the photo up in a “Photoshop” app, boosted the brightness and the two sides look pretty close to parallel, which would be correct.
Of course the user has to watch carefully to make sure the knife is clamped vertically and is not leaning to one side or the other. I looked at a bunch of photos of Hinderer XM-18 knives and it looks as if all have at least a small amount of flat where they’d be clamped. Ah, but I’m assuming here… My practice is to clamp ALL folding knives with the bolster pushed up against the clamp. I’ll explain that elsewhere.
As the thickness of the blade increases, (say, a machete as opposed to a filet knife) the centerline of the knife (the line that the apex should fall on) moves by one-half of the thickness change. The apex moves away from the fixed side and towards the free side. This means that the angle will increase on the fixed side and decrease on the opposite side. The Hinderer has a thickness of about 0.180", so the theoretical center of the blade would move 0.090". But compared to what? I measured a setup with my Buck 110 folding knife.
At the 22 degree detents, I measured 2.66" horizontally between the center of the ball joints and the center of the blade ( 0.12" thick")
I measured 4.85" vertically between the centerline of the ball joints and the apex of the blade over the center of the vise. This is the adjacent side of my triangle.
I measured a couple of diamond blocks and found them to be about 1.187" thick, resulting in an offset of 0.594". This means the base (opposite side) of my triangle is 2.067".
My Navy training trig says the tangent of my triangle is 2.067 / 4.85 = .426. The included angle (arctangent=0.426) is actually 22.54 degrees. My angle cube says 22.6 degrees. As near as I can see, both sides are identical.
Now if we switch to a Hinderer XM-18, which has a thickness of 0.185" the vertical centerline of the knife will move 0.033" to the right. This means that my triangles are no longer identical. Theoretically, the angle on the left becomes 22.9 degrees and the angle on the right becomes 22.2 degrees.
Not enough of a difference to worry about, but if you go to something thicker, the angle change does become a factor. I don’t know if it would be noticeable on the finished knife.
