Please consider that the scratches from prior grits are quite deep and are really difficult to remove with stones more than one grit step finer. Also consider that these deep scratches are not just cosmetic flaws, but extend all the way to the apex, where they have produced a deep notch in the apex. If you truly can discern between scratches as to which grit produced it, good for you, but if miss it, you’re in for a lot of stoning.
While we usually see changing direction in the scratch pattern as a means of most easily removing the visible evidence of the prior grit, the fact is that those scratches tell you something about the condition of the edge at a macro level. A less-than-perfect polishing job will certainly produce excellent practical cutting edges, but a deep scratch in the bevel field is usually a deep scratch at the apex. You may find that these points along the edge will snag when trying to cut a less-than robust sheet of paper. Those of us who are possessed by the obsession of achieving pure cutting nirvana will take that as a sign of failure.
For knives I sharpen to be working tools in the field, I usually use only four grits: 400, 600, 800 and 1000. I have my stones stored on a rack of pegs, with each stone mounted with a top and a bottom, left side and right side. This means I always hold the stone in the same hand and the same direction. I have a sheet of paper hanging on the wall next to me, telling me what direction to use with each grit. For instance, 400 is always down and toward me, 600 is down and away from me, alternating similarly with the 800 and 1000’s. For stones under 1000-grit, I always use down-strokes (edge leading) if the stone will hit the apex. If I’m not there yet, I’ll use scrubbing strokes to speed the process along. The objective is to not rip any particles free at the apex, which is much more likely with an up-stroke (edge leading).
For 1000-grit I will generally use the same down-strokes, but will switch to gentle scrubbing strokes as I near the finish. When I get to the last few strokes of the last grit, I’ll do alternating down-strokes; left-right, left-right, etc. for maybe 5-10 strokes on each side.
After 1000-grit, I usually jump to 6-micron film. Film requires that you use up-strokes to keep the edge from digging into the soft film, but by that time, you’ve eliminated the raggedness of the edge and the film being used edge-trailing will not add to it.
You can start out with the 14X loupe, but try to find an old laptop and monitor and a USB microscope. It will add hugely to your experience and confidence.
