Interesting topic for sure!
For some reason I have a hard time with steeling properly. I have several steels. That is what happens when I struggle with something, I try to get better tools. The best of the bunch (for me) is one that is entirely smooth, and that I buffed with several grades of compound to get to a close to mirror polish.
The ones with teeth or rings just seem to tear up the edge. It can feel a bit sharper for a short period, but not very long. I have better luck with a very fine ceramic cylindrical hone.
Part of the problem is that some of my knives are harder than my hsteels. Most common steels are around 60 Rc to maybe 63. I have knives that are 63 Rc and up to a claimed 68. I have been lusting after a borosilicate hone. At a Rc hardness of about 80 (equivelent) this would solve that problem. The problem is, they are very expensive. I worry that I still couldn’t get good results after dumping more money on the problem.
We had a thread where we talked about steels and it show some photos at the edge. Might be a good read in relation to this thread.
http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=3&id=2923&Itemid=63
Here is another interesting link:
http://zknives.com/knives/articles/wssteeling.shtml
I have mostly been using strops between sharpening. I tend to think that I need some abrasive to get much done in a relatively short amount of time. I typically use a 3" X 12" horse butt strop with 1 micron diamond on it. If I am being OCD, I have various levels of stops down to 0.025 micron CBN on nanocloth (these just normally used for “show off” knives). I use this process for the kitchen knives as well as hunters and folders. I do the kitchen knives just before using them usually. This takes me through prep for a full meal easily (if I don’t screw up) This is not as convenient as steeling, obviously, but it does keep the edges in reasonable shape until the next round of sharpening. I like the results.
As an aside. I got a Spyderco Military in S30 V a couple of months ago. It came pretty sharp out of the box, but not as sahrp as I want my knives to be. I decided to do an experiment. I stropped starting at 1 micron, then 0.5, 0.25, 0.120 and 0.1. About 30 strokes per side with each grit at maybe 20 degrees. I have been using it a couple of days per week for light duty stuff (cardboard, tape, rope, cutting sandwiches, etc)for the last couple of months. It is still pretty darn sharp. I think that using a strop with the right abrasives is a very good approach for maintenance.
Now, if I could just get my steeling technique to be consistent…
One other thing that I have been doing quite a bit is to use my belt grinder to maintain my edges. I use a leather belt with some cromium oxide on it. I use the unsupported part of the belt (off of the platen) to get a bit of micro convexing of the edge. I use as little pressure as I can while still maintaing contact with the belt. One or two passes on each side leaves the knife very sharp. I just ake 10 minutes to do all of the knives that I might use in any given food prep session and I am good. This is possibly even less convenient than the strops, but with a bit of planning it actually saves time.
