http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=13&id=7173&Itemid=63#7175
Some of the above was taken out of context. Seems like a tactic to make a point, rather than tell the entire story.
From Clay, same post that was extracted above:
"[i]Personal experience
I just returned from the New York Custom Knife Show where I sharpened several hundred knives over the weekend. I alternated between using the Pro-Pack 2 and the Pro-Pack 1 throughout the show. Neither the customers nor I saw any difference in sharpness or edge appearance from one system to the next. The main difference is in the way the units feel to use, the range of angles available and the ability to adjust the angle to a very fine level with the Pro-Pack 2. All the knives sharpened, regardless of which kit I used, were equally sharp and equally beautiful."[/i]
From Bob Nash, same thread:
[i]"I continue to be extremely happy with my original arms - I own both sets and use them both, but I use my original arms much, much more, getting amazing results with no visible faceting or angle variance showing up. I use my ball joint arms primarily with my choseras and shaptons, to match the angles more precisely.
My advice for folks has been basically - if you are going to be sharpening straight razors or know that you are going to be working with natural/manufactured wetstones that are going to wear with use then you should probably go for the ball joint arms right away. They are also a must for piece of mind if you know you are going to want the most consistent angle you can possibly produce no matter the thickness of the stone or strop you are using. If you aren’t in that group, start with the basic Wicked Edge Sharpener kit. You are going to have more angle consistency and control and you are going to get results that can’t be achieved with nearly any other system out there and you are most likely going to be very happy."[/i]
That is a bit more of the story on the Arms.
There are those among us that are never really satisfied and feel the need to tinker with something good to try to make it “better”. I am in that group BTW. The oringinal arms are plenty good, and will yeild excellent results without modification. I used them on 100s of knives over about a year and a half, and was thrilled with the results, as were my customers.
BTW, checking for discussions on this forum does not give any indication of what the general population that has purchased the WEPS system is concerned about. In this context, I would be willing to bet that the percentage of people owning the WEPS that have worried about arm play with the original joints, much less actually modified them, is very low. This means that even though the subject has come up here and a “few” have posted about it, it does not mean that the difference has been significant to the vast majority of the WEPS users.
