It would be great to have a device to be able to sharpen a small blade i.e. Small slip joint or Swiss Army knife.
This is what some folks have been using. I picked one up for my swiss army knife. will try it out over the holiday weekend!
http://www.amazon.com/gp/product/B00CD7X1OA/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
[quote quote=“Zamfir” post=19810]This is what some folks have been using. I picked one up for my swiss army knife. will try it out over the holiday weekend!
http://www.amazon.com/gp/product/B00CD7X1OA/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1[/quote]
I haven’t seen ppl using that specific one… that is great! Tormek makes good quality stuff too.. how ingenious is that!
Won’t the WE low angle adapter work for that?
https://www.wickededgeusa.com/product/wicked-edge-low-angle-adapter/
I used to use this mostly to get lower angles on blades. The problem is centering the blade which can be compensated for and compression of the handle. Some knives sit funny in it also.
I just used the Tormek adapter last week and it’s a great answer for blades that are really small. For instance, a Swiss Army knife with a blade only 3/4" long and 3/16" wide. The Tormek gadget puts the blade directly over the WE vise in free air with full access. I highly recommend it as an add-on to the WEPS.
What an excellent add-on to go with everything else!
Taking inspiration from Josh and others I tore down, cleaned, lube, & polished the entire system tonight looking for ways to improve and do more things with the WE.
This seems like a must have for all kinds of little stuff. Thank you!
Would be great if you have a picture shown mounted on WEP! ![]()
It is like drag racing. Having the Wicked Edge is like having a top fuel high end car. To go just a little faster ist is harder and harder. More expensive too. To get the edge that much more perfect takes lots of practice and skill. There are some small mods a person can do to make it a little better. But we are already in the high end bracket. I am going to try a neat idea tonight involving spring ball bearing plungers on my lapping film paddles. I will post some pictures.
Hi Vic:
Here’s a photo I took of the Tormek Small Knife adapter holding a mini leatherman. I put a pad of graph paper behind it just to make it more clear and I didn’t take any care to level out the knife, so please don’t be too critical.
Works ok for me.
[quote quote=“tcmeyer” post=19864]Hi Vic:
[/quote]
Mahalo, my good man!
You had made it very clear, I will get one of this for sure now!
Again, thank you and have a happy Thanksgiving!
So I received mine a few days ago and figured I’d share my thoughts on this handy addition to the tool kit… First test subject was a Kershaw Scallion, slight recurve blade, going for a nice low dps of 14-15.
I found the jig clamp mechanism to be excellent. I thought it would be more fiddly, but it was easy to loosen with thumb screw and adjust the blade to vertical. Once screwed down blade was very secure. Nice!
The ability to clamp the jig in the WE vise to adjust the front/back/up/down AND adjust “leaning” angle also excellent & I think will make it valuable for all kinds of small jobs.
I’ve only had it a few days but what I’ve noticed is the knife tended to slightly wiggle(the entire jig itself flexes just a bit) side to side when sharpening towards the tip under medium pressure. I was able to get an excellent result by decreasing pressure, slowing down, and using the off-hand to stabilize the blade so not a deal breaker.
I was wondering if others that have this noticed the same thing? Maybe you next time I could try to get the jig higher up on the handle of the knife, that sort of thing… Regardless it worked and well. Thanks for the recommendation!
Aloha ![]()
Mr.Clay, reckon yall could come up with something like this? I know it is a pain in the butt to try to sharpen my trappers on the WE. You can raise the blade in the vice, but I don’t feel that you could get repetitive clamps time after time, also the higher you lift the blade the more unstable the knife seems to get. Thanks
