So, I am having a brain fart here.. we make a burr, then go up in grit until the lats grit..recently for me it has been 1K plate. Some people say making a burr is bad because it has made a week and stressed part of the blade edge..
question 1:
After confirming the burr happens on both sides..is there something special I should be doing to remove the burr and then continue?
question 2: sharper on one side?
I was sharpening a cheapo kitchen knife, confirmed bur on each side, then moved on with alternating strokes and worked my way up in grit to 1K. Then I would feel the edge with my fingers on both sides and it would grab more on one side then the other. (similar to feeling for a burr but straight across rather than dragging fingers from spine up along the side to feel for the burr) makes me think I have a burr still hanging off to the side that grabs more (or something?)so I hit the side that side more until both sides felt to “grab at my fingers the same” when dragging them across in both directions. This made me think of some other times when I finished up a knife and it would shave good on one side but not as well on the other.. What does a feller do when this happens? So The blade feels nice and sharp and was for sure apexed..but one side saves and the other not as well. What is the right process to fix this..or better yet, how to keep it from happening in the first place?
Thanks!
-Eric
