So after I made my one bevel larger both sides set a 15 deg notch second holes on B I read clays video about filling the clamp is there anyway to even out what I have now thanks for any help.
If you check around, you find quite a bit on this subject. The uneven bevels seem to be pretty common in Spyderco FFG knives and they require special attention when clamping.
Check out this thread:
http://www.wickededgeusa.com/forum/6-techniques-and-sharpening-strategies/13084-bevel-angles
There’s lots more on this forum covering the same issue. Good luck and welcome aboard! There’s a lot of really good people here who will jump in to help you.
Hey Magnumfloyd, welcome to the forum! Enjoy your WEPS!
There are lots of resources for beginners that also include tips for mounting full flat ground blades. If you look under “Resources”, you find the FAQ and the Wiki that both cover FFG blades.
Success! And don’t hesitate to ask if you have more questions.
Check out my post here: http://www.wickededgeusa.com/forum/9-basic-techniques-and-sharpening-strategies/13088-why-are-my-blades-tilted-in-the-clamp?start=10#18577
If you have any more questions, don’t hesitate to ask.
