With the riser block, do you find the standard rods to be at their limit? It appears maybe the rods sit a little higher in the new joint/adjustment assembly than the old universals. I could be wrong though.
I’m pretty sure you’re right on the reason for the longer rods. I had to make rods which were even longer, because my addition of bronze bushings tended to slip off the end (the bore is way over-sized).
BTW, the rod end ball joints have 1/4-28 threads, not 1/4-20. Assuming you have a die handle, you can buy a die for about $15 and a 3’ length of polished, tight-tolerance rod for only about $5, but I think WE would make you a set of whichever length you ask for.
With the riser block, do you find the standard rods to be at their limit? It appears maybe the rods sit a little higher in the new joint/adjustment assembly than the old universals. I could be wrong though.[/quote]
Yeah, the new joints do raise the rods up to where they need to be… but for consistency’s sake I did not want any part of my paddle to go off of the end of the rod while I was sharpening =) It’s just a little “extra” that I personally wanted after I got spoiled on the first gen w/ longer arms!
[quote quote=“tcmeyer” post=18341]I’m pretty sure you’re right on the reason for the longer rods. I had to make rods which were even longer, because my addition of bronze bushings tended to slip off the end (the bore is way over-sized).
BTW, the rod end ball joints have 1/4-28 threads, not 1/4-20. Assuming you have a die handle, you can buy a die for about $15 and a 3’ length of polished, tight-tolerance rod for only about $5, but I think WE would make you a set of whichever length you ask for.[/quote]
your a beast tom! If i EVER have to mod anything i need to make SURE i consult you first! I love engineers! ![]()
No worries there…I own a great tap and die set.
Got the upgraded arms in today. Thumbscrews are taken out completely and the micro adjust screws will not budge at all. Pretty disappointed here. Had to take it off the angle bar because of all the torque I was putting on it but even holding the arm assembly in my hand, I can’t turn it like it was red loctited in there. Unless I’m completely missing something here besides turn left or right.
Edit: already spoke with Kyle and getting a new set sent out Monday.
Awesome… can’t wait to hear your experiences!
[quote quote=“uofaengr” post=18403]Got the upgraded arms in today. Thumbscrews are taken out completely and the micro adjust screws will not budge at all. Pretty disappointed here. Had to take it off the angle bar because of all the torque I was putting on it but even holding the arm assembly in my hand, I can’t turn it like it was red loctited in there. Unless I’m completely missing something here besides turn left or right.
Edit: already spoke with Kyle and getting a new set sent out Monday.[/quote]
Got the replacement upgraded arms in a few days ago, and they work much better. After awhile of flipping the angle bar around and slightly moving it between grits, you start to get a feel for how much movement moves the arms X number of degrees. I’m really liking the micro adjustment feature and am trying it with the angle bar in the normal position with detents facing towards me. The brackets seem to “lock” positively at each degree mark making it easy to quickly get to your “rough” starting position before micro adjusting. I also appreciate that socket cap screws with enlarged thumb grip heads are being used for positive tightening.
I’ve quickly learned how much of a turn yields how many tenths of a degree of movement so it’s pretty quick measuring and readjusting between grits. The new arms give a feeling of more precision when sharpening. Everything feels tighter and I think they’re worth it. They’ve helped me to get some of my best polishes yet. The diamonds have gotten really smooth; the 1000 grit stones feel like glass on the edge now and leave a hazy, shiny finish. I agree with Josh that it helps to not go lower than the 400 grit stones unless you just have to. My best polishes thus far have been from 400 forward with the new arms.
It’s really hard to beat this system, I must say.
A question regarding stropping…I’ve been using rubbing alcohol to spritz the strops for awhile now. On the 5 and 3.5 micron paste strops, they slide smoothly over the edge. The roo strops with 1 and 0.5 micron CBN spray slide smoothly for the first ten strokes or so then they start getting really sticky on the edge. I think I remember reading a post about the roo strops having more stiction? If so, then I’d say that’s definitely true. My question is do you respray your roo strops often with alcohol? It seems like I have to put a lot of pressure on the strops to get them to travel the edge. I strop at one degree below but wonder if this additional pressure is too much for the edge as I’ve usually always stropped with really light pressure. Most of the edges are hair whittling, but I’ll admit some are more difficult than others.
Looking good man!!
I have never used rubbing alcohol other than trying it out once or twice… But I found that it evaporated so fast it didn’t do any good.
I just recently had a problem with my 3.5 strops sticking so badly that it was leaving residue all over my mirror bevel and was making it hard to strop! I solved the problem by “cleaning” the strop with some amsoil motor oil which cleaned off the gunk and lubricated it. Then I put a tad more of fresh abrasive on it and it worked great!
So oil may be a consideration to take…
Hmm cleaning with Amsoil? I would’ve never thought of it. Well I cleaned my strops about 10 knives ago or so with denatured alcohol and a toothbrush. Got them pretty clean. The first time I put paste on the strops I did it dry and rubbed the two strops together which yielded a decent amount of excess coming off on the edge for the first few knives. In the piece of paper that came with my strops, it said that wetting the strops with alcohol before applying the paste could help it get in the leather better (if I remember correctly) so I tried that this last time. It made the paste thinner and spread on the strop much easier. What I noticed was that the strop turned black much quicker, only after a couple knives. The strops before I cleaned weren’t even as black as they were after 5 knives or so after this last cleaning and reapplication.
I only get the sticking with the roo strops which are sprayed and not pasted. They will stick so bad that they, even with no paste, will leave residue on the bevel. I wish Clay or someone had some microscopic pics of edges with stropping with alcohol and no alcohol.
How about cleaning the strops with a dedicated leather cleaner like Lexol? I’ve never cleaned my strops in any other way than scraping the dirt off, but I read it on another forum. It might help.
[quote quote=“uofaengr” post=18558]Hmm cleaning with Amsoil? I would’ve never thought of it. Well I cleaned my strops about 10 knives ago or so with denatured alcohol and a toothbrush. Got them pretty clean. The first time I put paste on the strops I did it dry and rubbed the two strops together which yielded a decent amount of excess coming off on the edge for the first few knives. In the piece of paper that came with my strops, it said that wetting the strops with alcohol before applying the paste could help it get in the leather better (if I remember correctly) so I tried that this last time. It made the paste thinner and spread on the strop much easier. What I noticed was that the strop turned black much quicker, only after a couple knives. The strops before I cleaned weren’t even as black as they were after 5 knives or so after this last cleaning and reapplication.
I only get the sticking with the roo strops which are sprayed and not pasted. They will stick so bad that they, even with no paste, will leave residue on the bevel. I wish Clay or someone had some microscopic pics of edges with stropping with alcohol and no alcohol.[/quote]
The reason the amsoil works so well is that it has detergents in it so it disolves the gunk which helped me out greatly. But I would think that ANY kind of oil would work good for making it slicker and lowering the stiction.
I have roo strops w/ .125 cbn, and while they do stick slightly, it’s not all that bad actually. So I don’t know why you would be experiencing this?
Possible that the denatured alcohol is drying the strops out too much? BUT, I cleaned the pasted strops with this also, and they don’t stick at all.
Did you just dip a brush in the oil and scrub the leather, or did you do any kind of soaking?
neither… and I didn’t do it on my roo strops so I can’t say how they will react but I think it would be similar. but on my cowhide stock WE strops I did it to one set and it worked great… this is what I did: I took 1-2 drops of oil right on the strop, rubbed it in with a finger, then took a paper towel and wiped it until dry. Then I re-applied paste lightly. It didn’t get all the black out, but some came off, plus I feel as if it hydrated the strops more.
