found hereSo while I am in the process to find a good sharpening wheel to go on my variable speed bench grinder, I came across this… ()
"Diamond and CBN wheels come in several bond types: Resin (most common), vitrified, metal and electro-plated. Resin is used in most tool room and production applications. Vitrified and metal bonds are newer bond types with specific applications (We won’t go into a lot of detail with these as they are somewhat rare and more expensive and almost always are custom made special order items). Electro-plated wheels are very common and are typically found in cutoff wheels and low demanding abrasive grinding such as for plastics.
Resin wheels are made much like a traditional grinding wheel with a thick bond/grit layer usually between 1/16" and 1/4". Electroplated wheels are a much thinner thickness. In both cases, the bond layer is applied to a hub which is either aluminum or steel made to the specific profile required.
Like traditional grinding wheels, Diamond and CBN wheels are used in a variety of processes and with a variety of materials. Typically, diamond wheels are used strictly on carbides and CBN is used on steels. Some manufacturers produce a ‘hybrid’ wheel which is a special grit that will grind both steels and carbides (Typically used on parts that require grinding of carbide and steel at the same time). Plated diamond wheels are used on non-ferrous materials such as plastics, rubbers, nylons, fiberglass, etc."
So I guess my question is, why do we use diamond plates instead of some type of CBN plates… what is the difference? Would it make any practical difference in longevity of the plates or the actual edges themselves? Or does this only make a difference on a high speed wheel?
Those of you with experience in metallurgy, engineering, or just plain know how to do research (anthony… ahem) please weigh in on this and try to explain weather it would be a good idea to get some CBN plates mounted to the WEPS paddles or not… I found a company who can do it anyway =)
PS. i have seen some info lately on the atoma 140’s mounted on WEPS paddles… it appears as if they work much better than the stock 50 grit, does anyone have any experience with this? I myself have noticed that even the 50’s take a while on a knife that really needs to be re-profiled.
